Results 1 to 7 of 7
Thread: Atc 200 revs up & down by itself
    Aug 2011
    Bangor Saskatchewan, Canada
    91
    My 1982 Atc 200 revs up & down by itself when idling ...What could be causing this? ...( it's really annoying because it's always revving up & is hard on the clutch unless I start it in gear...)
    Here's a video of it doing it at the beginning.
    http://www.youtube.com/watch?v=3QHlr...1&feature=plcp
    ~ 3 WHeeLeRs 4 LIFe! ~
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    im thinking air leak or worn rings/piston
    to check air leak spray starter fluid around the outside of the carburetor and intake manifold if it revs or sounds differant theres an air leak
    to check the rings/piston for where do a compression test should be like 142 - 155 psi or something like that
    good idea to post a video that always helps
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
    glendive, montana
    1,822
    have you checked the cam chain or valves yet, also go through the carb an pay extra attention to the main needle, to see if it is wore, or jumping up and down.
    Aug 2011
    91
    The cam chain is good & The carb is very clean. I have not checked the valves or for an air leak yet. It's probably got an air leak, the sun deteriorated lots of rubber on it. I will have to check the o rings on the intake.
    Jan 2011
    Brazil, Indiana
    2,087
    Carbs will do that when they get wore out. You will drive yourself nuts trying to fix it unless you get a new carb.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2012
    Amana Iowa
    184
    if you buy a new carburetor the twenty dollar one from eBay on mine runs great
    1984 Honda 200M
    1984 Honda 200M
    1990+ Xingfu Hunter
    1986 Suzuki SP200
    Jan 2011
    Brazil, Indiana
    2,087
    Quote Originally Posted by WJG1000W View Post
    I have used a couple of those too. If the carb is a close enough match I like to put the genuine factory jets in it. The jets on the china knock offs are hit and miss on being the right size.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
