Results 1 to 8 of 8
Thread: Best way to remove old broken exhaust studs?
    Apr 2012
    Whiteman AFB, MO
    20
    I will post some pictures later, but just getting some advice. When i removed my exhaust the nuts broke off and now I have old crappy bolts sticking out. They are pretty brittle as well, what is the best way to remove them and replace with new ones? Do they unthread or are they just sunk in? Please let me know if you have any ideas or have had the same problem.
    Dec 2009
    BFE
    1,202
    Well the best way to repair it would be to take the head off the motor and have a machine shop drill them out. Thats what I did on my 350x they drilled out all 4 studs and I was able to reinstall the stock size studs. They only charged me $40 and they said it would have been less but the guy broke his drill bit trying to drill one of them out.
    The other method that usually dosent work is to try and drill them out with a hand drill. This usually results in damage to the head. I have seen guys do this this way and have a decent repair but I myself wouldnt do it.
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Apr 2012
    Whiteman AFB, MO
    20
    That's kinda what I was afraid of. Do they thread out or are they just ring shanked in?
    They thread out but if I'm not mistaken, the threads have a bit of a "lock" pattern to them. Like suggested, it's best to pull the head and have a professional do it.
    Cold Lake, Alberta, Canada
    3,019
    Doesn't dirtcrasher do this type of repair on a regular basis? Just thinking out loud.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    He was but he's been a bit busy lately with work.
    May 2012
    Seymour, Indiana
    4
    You might try heating them up and tapping them on the end to loosen the locks up then take them out. If all else fails off to the machine shop you go.
    hogmuffin's Avatar
    hogmuffin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Dallas, TX
    341
    never tried this on a trike engine before, but in other situations, if there is enough room left, you can try welding a nut on the end of the stud and then while they are still hot from the weld, try unscrewing them.
    1985 KLT 160
    1985 YTM 200ERN
    1984 YT 60
    Reproduced KLT 160, 110 decals for sale
    Reproduced YTM200ERN decals for sale
    http://www.3wheelerworld.com/album.php?albumid=2655
    Feedback thread: http://www.3wheelerworld.com/showthr...uffin+feedback
