Results 1 to 14 of 14
Thread: Is it true ?
    Feb 2003
    southwestern NY
    641
    Is it true ?
    Do the rear hubs from an 86-87 200x make the 83-85 200x +2'' wider ?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: Is it true ?
    Quote Originally Posted by YTZ250#1
    You heard correctly. The difference in the off set of the hubs do make a difference. I have a set of 300ex hubs that are the same ( not for sale at this time, lol ).
    Howdy
    Aug 2003
    138
    they sure do, plus they are the same ones used on the 250x/300ex quads, so I don't think Honda will be discontinuing THOSE anytime soon..
    If I can't fix it, it ain't broke!!
    Aug 2002
    Creswell, OR
    889
    here is a pict of the difference....I actually used the red ones on the 110 for my babies...
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Minnesota
    784
    Thats interesting, but since your using the '86 hub do you need to use the '86 lug nuts? I know the 83/5 lug nuts don't taper like the '86's in the picture. Or can you put '83/5 nuts onto a '86 hub?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by hrc200x
    If you use the 83-85 200x rims then you can use either nuts. f you use the 86-87 200x rims ( same bolting style as 85-86 250r's, 350x's, and a lot of later quads ) then you need to use the tappered nuts.
    Howdy
    Detroit, MI
    837
    So those hubs will fit most any Honda quad/trike correct? If so then they will make most any honda quad/trike wider right? (except the 250x/300ex oubisly).
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Ok, let me clear some things up here. I think I confused a few people.
    The hubs will fit a lot of machines, but they won't fit all machines.
    The hubs Do not fit on the 250es /sx, & 350x axles, I am 99% sure they won't work on a 85-86 250r either.
    I do know the hubs will fit on the axles of these machines below. You will need rims that fit the hubs though. Note: To use the hubs on any of the machines below you must use a rim that has a 4/110mm bolt pattern.
    75-78 atc90
    All years of these Honda models below:
    ATC110's
    ATC125m's
    ATC185, 185s
    ATC 200, 200e, 200es, 200m, 200s, 200x,
    The hubs do fit on other makes also. Some Yamaha & some Kawasaki. I do not know for sure what all models though. Sorry.
    In my posting above I should have been a little more clear. So let me explain quickly. The 85-86 250r and the 350x rims will fit the 86-87 200x hubs. But the 200x hubs DO NOT fit the 85-86 250r or 350x OEM axles.
    Thanks
    Howdy
    Aug 2002
    Creswell, OR
    889
    Now that you have caused HONDA to wonder why suddenly they have increased sales on 300ex hubs, Lemme also ad they fit the 70 atc too :-D
    www.3wheeler.org
    whiteboarder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    thats some good information to know
    1985 atc 70 (sold)
    1985 200x dg pipe and k&N filter
    need rear brake caliper for 200x
    Feb 2003
    southwestern NY
    641
    Well Damn!! Now that I know that I want 2 sets so I can make it + 4
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by jenndnn3
    You are correct, I did forget to list the ATC70's on there. Thanks for pointing that out.
    /me gets 3 lashings with a wet noodle. hehe
    Howdy
    Rittman, Ohio
    6,276
    You mean hubs like these?
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2444495352&category=43 972
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by TimSr
    lmao, Yep those are the ones. You can add that model to the list of machines above. lol
    Howdy
