Results 1 to 14 of 14
Thread: powder coat exhaust
    Mar 2003
    NJ
    911
    powder coat exhaust
    Is it possible to powder coat an exhaust pipe? or does it get too hot and the the powder coating melts off?
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Clarks Summit PA
    1,236
    ive done a few, and yes they hold up.. as long as factory, no.. but surely do last quite a bit of time, depends on how thick the pipe is and so on, i feel it does last alot longer then the spray can of heat paint..
    Ride it like you stole it! And never look back! They are too far behind to see!
    May 2002
    Cortland, NY
    1,195
    If you're going to spend the money get it ceramic coated.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    May 2002
    Cortland, NY
    1,195
    Quad: '86 TRX 250r
    Bike: '00 ZRX 1100
    Apr 2003
    Bay Area CA.
    2,638
    what kind of paint did they use on the pipe when it was being made at the factorty, back in the 80s?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Dec 2002
    Janesville,WI
    573
    Here's mine ceramic coated.
    Mar 2003
    NJ
    911
    that ceramic coating is nice. how much does that cost? i might just chrome the pipe, not sure.
    thanks for the suggestions. ceramic coating does look nicer than powder on exhaust.
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Dec 2002
    Janesville,WI
    573
    Quote Originally Posted by sportvette
    The cost depends on the condition of the exhaust.I bought the pipe new and within a few hours on it,it rusted pretty bad cuz of water,dirt,etc..The black coating that DG puts on the header pipe is crap!Because of the rust and trying to get most of it off,when he coated it,it shows some pit marks in it.But,only if you look at it close-up.It cost just as much as the pipe! :x
    Mar 2003
    NJ
    911
    how does the ceramic coating hold up? is it rusting out fast, or holding up well?
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Dec 2002
    Janesville,WI
    573
    Haven't used it yet.It's going on the project x.It's suppose to hold up for a long time.It's better than a chromed pipe,cuz it's like powdercoating,it's baked on.
    Oswego, IL
    1,858
    How much is it to have ceramic coating? and were did you have it done?
    Dec 2002
    Janesville,WI
    573
    Quote Originally Posted by vartiak15
    Probably anywhere from $75-$200 depending on the condition of the pipe.It was done at Prism Powdercoating in Crescent,Pa.
    ange's Avatar
    ange is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    utah
    195
    It shouldn't rust, at least not for a very long time. Ceramic coating is now common place on most high perfromance header(s) in the auto industry where the header(s) are visible and you want them to look good for a long time.
    Indiana
    192
    its not powder or ceramic coating, but a friend of mine is into hot rods andtold me about the coating he uses on his hot rods headers. he has had the headers on his camaro coated with POR(paint over rust) for 8 years without discolor or rust. here is the link:http://www.prp-porstore.com/faqhtpc.html
    Tim is the name
    85 350X(86 motor)
    83 200X(stripped down for a total rebuild)
    85 200S(project)
