Originally Posted by
Deathrocket
I think that would probobally work if it was a stock trike, but its not stock, so that being said, heres what its got, 81 250r dg pipe, muffler, reed spacer, stock reeds, bored to 72mm (IIRC) 480r boot and the throat of the carb mics out to 1.515" which google says is 38.5mm so I assume its a 38mm kehin pj 38mm oval slide, now I have been told that this carb is way to big for the trike but before the motor gernaded (piston circlip let go and jacked the bore all up) it ran perfect, now that it has sat and while sitting in my tool box the needle got bent and its running stupid rich, I can't see this as the cause of the condition but its not right so it should be replaced anyway, so what needle is the replacement for this one?
