Results 1 to 3 of 3
Thread: starts but wont idle 74 honda atc90 k2
    Feb 2012
    Hammond, Indiana
    17
    Angry starts but wont idle 74 honda atc90 k2
    ok just recently i had new piston and rings in the motor. I had it done at honda the dude honed it, i guess he did everything. I cleaned the carb but when i did it i tighted the 2 screws on the carb. The trike will start but wnt idle it idled once then when i gave it gas it bouged out so i tryed adjusting it but now i got it outta wack, i wanna ride its gettin warm... HELP PLEASE
    Cold Lake, Alberta, Canada
    3,019
    Whoa...slow down. A little history on the machine please. Did it run before you had the motor work done? What two screws on the carb are you talking about? The idle screw and air/idle screw or the two bowl screws? Do you have a service manual? You're going to need one.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    try to adjust the brass screw on the bottom 2.5 turns out or something like that to get a starting point
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
