I just starting working on a honda atc 200s that has no spark. I have changed the coil, and the cdi. I am thinking maybe the alternator is bad, can someone give me an idea of how much voltage it should put out when you use the pull start??
Check the resistance of the stator coil, the one befind the pull starter. It resistance between the black/red wire and ground should be 245 ohms. I had been told that these bikes had a weak ignition system and after having trouble with my 200s and my friends 200s I am starting to belive it. I have found that this coil is usualy the problem.
-Andrew
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
stator is almost always the problem.
Check the black with red striped wire with a Ohm meter. To do so unplug the wire from the wiring harness and put one test lead on the terminal, put the other lead to the motor. The correct ohm reading should be between 215-245 ohms. If it checks bad you will need to replace the exciter coil or stator.
Howdy
Can someone please tell me where to find this connector? I'm having a no spark issue with my 200s.
1985 Honda BigRed 250ES
runs good all original
Restoration in progress:
1980 Honda ATC 110
1985 Honda ATC 250SX
1982 Honda 200ES BigRed
1984 Honda 200S
1984 Honda 200S parts bike
1985 Honda ATC 110
1983 Honda ATC 110 parts bike, runs but smokes
Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
I figured it out, bad stator. What stators will interchange?
1980 Honda ATC 110
1984 Honda 200S
1985 Honda ATC 110
ricky stator makes new upgrades.
any 200/185,s,es,s will work
________________
https://www.mikesatvfix.com
I got a 200e stator which is different, thank you.
1980 Honda ATC 110
1984 Honda 200S
1985 Honda ATC 110
interesting, my 200e and 200s are exactly the same. and they were factory. now are you looking at the wires coming out or the actual stator with the 2 wires itself? the wiring circuit coil will have more wires, but the stator has only 2.
________________
