Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: 70cc lifan carb settings??? help please
    6,802
    Did you check your valve adjustments ? A tight valve will have the same symptom as your video is showing !!!! Probably not even a carb issue . Make sure the piston is at top dead center and see if you have a little play in the rockers .
    Apr 2012
    United States Illinois
    20
    I will check them. And the orings are good. After I adjusted the spark plug gap it had no bog. Revved right up. Until it warmed up all the way. Motor shouldn't have wear really since there's only a few hours on it. Be a few days before I get time to tinker more.
