Thread: Need help with front brake!!
    Apr 2012
    Reno, NV
    6
    Hey guys picked up a basket case, front brake master stuck in, it does move slowly, no brakes though, how do I pull it apart and rebuild or clean it up and he it working? I can't seem to find a Snap ring or anything.
    It might be easier to get a more modern master from a newer dirt bike or quad.
    Also, it helps if you tell us what make/model your trike is.
    Apr 2012
    Reno, NV
    6
    Sorry, it is a 1985 200x, but I'm replacing the bent frame with a good used 1984 I have. What model of bike should search for a master cylinder? I suppose anything with a banjo fitting would work... I'm on a budget, would prefer to stay around 50 for this part if possible...
    Just about anything will work as long as it doesn't interfere with any other controls you have on the bars and it's the right size for your bars.
