Results 1 to 9 of 9
Thread: Finally Started my 200S rebuild.
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    I've had it apart for awhile, but finally got around to doing stuff to it.
    In these pictures I've painted the frame, foot pegs and skid plate with PlastiDip.
    I have 4 coats of the black on all and am going to hit the pegs and skid plate with the silver metalizer from PlastiDip as well.
    I showed a picture of the rims to give you an idea of how rusty the frame, pegs and skid plate were.
ID:	146627Click image for larger version.
ID:	146628Click image for larger version.
ID:	146629Click image for larger version.
ID:	146630Click image for larger version.
ID:	146631Click image for larger version.
ID:	146632Click image for larger version.
    Next is to get the wheels done with base black coat then the gold metalizer.
    Do the triple tree black with the handle bars, chrome steering plate and the fork housings the silver.
    Probably going to do the front hub and rear bearing housing and rear hubs gold as well.
    I want to go white on the plastics, but I can't find any white hand grips for the life of me.
    Justin
    1985 200S - fixer upper
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I saw someone on here who had turned their bolts and etc into a zinc color. Did they do that themselves or have them shipped off?
    If you can soak them yourself or something like that, what is the product called?
    Thanks.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I took off the front axle and hub. I had to use heat, blaster and a pipe wrench + cheater bar.
    As you can see the side with the hex head is all scarred and the head is stripped.
    I had tried to remove it once with an impact, didn't work so the other day got it out with the wrench.
ID:	146676Click image for larger version.
ID:	146677Click image for larger version.
    I looked in the manual, and it seems like the axle should just slip out of the hub, but it wont. I was tapping on it with
    a (thread side) to try and knock it out, no luck.
    Does it come out a different way? I noticed a collar on the other end, so wouldn't think it comes out that way.
    Thanks.
    Jan 2011
    Avon, Minnesota
    641
    is should practly fall out. the threads slide through the bearings not the nut end. your bearings are probly froze to the shaft and it will take some kind of penatrating oil and an amount of force
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Quote Originally Posted by yamaha driver View Post
    By 'nut end' I meant the non-threaded end of the axle. If I were to hit on that with a , the collar would prevent it from coming out that way, right?
    I may scrape off those dust seals and see if I can get some PB blaster stuff in there easier.
    Thanks.
    Apr 2009
    Oklahoma
    1,234
    it looks to me like what is says in the manual diagram it should just slide out. From your pictures yours looks a little gunked up so
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Yeah I'll just keep some penetrating stuff in it for awhile. Is there anything I can buy and put in a 5 gallon bucket to just soak this thing in?
    I'm replacing the brakes and bearings/seals anyways.
    Feb 2009
    Rome,NY
    1,046
    as for ninc plating check out Caswell ind they have diy kits http://www.caswellplating.com/electr...t-10-pint.html pretty $$$
    Apr 2009
    Oklahoma
    1,234
    Quote Originally Posted by MonkOFox View Post
    I use mineral spirits some on here don't like it but it works great for me!
