Results 1 to 15 of 15
Thread: Triz mod carb
    tippmann's Avatar
    tippmann is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    canada quebec Lac st-jean
    161
    Triz mod carb
    I bough a 38 mm tm mikuni but its a real pain in the ass to set up the tm needle are all different of vm etc
    So i read that keihin are better then mikuni and way easier to set up so im shopping for a pwk. Carb on ebay my z is ported dg pipe v force 185 psi compression wrench report recommand a 38 but i found a post ehere a guys prefer. A 39 mm and there is one on ebay that a 39 mm quadvent bored to 41 mm but its bid only price for now is 202 + 25 ahipping. And a brand new 39 mm pwk is 250 shipped ,, what should i choose ?And if its the bored carb what the max priceni should give for it ?
    Tri-z 1985 resto project
    Arctic Cat Prowler 440 90 --- raised handlebar -Homade cherry bomb exhaust ! - Custom Tuck tape seat cover - Sled Mod by SREDNECK
    Kawasaki Z1000 04 -- Offmarket front disk - Yoshimura tr-s carbon slip-on- Bmc air filter- Power commander 3- Airbox Mod- Inc flasher tail light-Action pro steering damper-
    IM FRENCH so sorry about all thoses grammar mistake o.O
    Dec 2007
    Southwestern NY
    517
    First question is, Are you still running a fuel pump or not? If you are, you need to find a pwk set-up for a fuel pump (smaller inlet needle, so the fuel pump can't overcome it). I buy used 39 pwks off of snowmobiles, for my Zs, since most all sleds use fuel pumps, they go right on. All you have to do is buy a choke assy, different jets and jet needle (52 pilot, cel needle, 165-170 main) I have purchased a few SETS off of late polaris xc600 & 700 sleds for DIRT cheap...less than $50 ea average!. If you are running a top mount tank, just about any dirt bike PWK will work, since they are set-up for gravity feed.
    Example:
    A fuel pump style pwk running off a gravity feed tank, will run the bowl dry on a good pull=lean and junk engine
    A gravity feed style pwk running off a fuel pump, will eventually flood and puke fuel all over because the inlet needle can't stop the pressure of the pump.
    Just keep this in mind while searching for a carb.
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
    tippmann's Avatar
    Nov 2005
    161
    Thx alot for this capital info is there any sled model i could get the air strikertech with the carb ? Or wich sled have 39 mm
    tippmann's Avatar
    Nov 2005
    161
    I dont find any but when you say it will flood because the inlet is too large withe fuel pump dont the extra fuel will simply return to tank via the return line ?
    Tucson
    1,652
    Quote Originally Posted by tippmann View Post
    Yes thats Exactly how it works!!
    tippmann's Avatar
    Nov 2005
    161
    So that do nothing if my carb inlet is for gravity
    Quote Originally Posted by zmpolaristech View Post
    Example:
    Tucson
    1,652
    Buy the carb you want, run the fuel lines like factory = running!!! That T is there for a reason To take the pressure off the needle and seat!!!!!
    Rittman, Ohio
    6,276
    With your setup, basically the same as mine, I think you're having so much trouble setting the carb up because its way too big. I haven't worked with the carb you have, or the pwk39, but the stock carb is 32mm, and using the same style of round slide Mikuni as stock, (which doesnt require intake change) I got very good results with a 34mm round slide Mikuni, but when I used a 36mm it was pain to setup, ran great n top end, but always ran rich everywhere else after several needle/needle jet changes, lost a lot of low end power, and was never very stable and was horrible in cold weather. I think most of the people using Keihen are using the stock 250R one, which I think is 34 or 36? The point is, I think the only thing to be gained by putting anything larger than a 36 with your setup - ported cylinder w/ DG pipe, is lots of headaches. I'm back to stock carb on my MX TriZ, and nobody is leaving me behind in the straightways and the 34mm Mikuni round on my trail machine.
    I agree completely! There is nothing to be gained by eliminating it.
    Did you ever find what was causing your coolant leak?
    Dec 2007
    Southwestern NY
    517
    Quote Originally Posted by badass350x View Post
    The T only relieves SOME pressure...believe me, their is still a ton of pressure in that line when running, enough to overcome a large inlet needled carb.
    SAY IT!!!!!
    tippmann's Avatar
    Nov 2005
    161
    Its ok aboutthe leaking notsure about thereal origin of the problem
    Mexico
    9,014
    Example:
    Very interesting. I posted this a few weeks back http://www.3wheelerworld.com/showthr...I-Z-Fuel-Pumps
    What you are saying fits my problem bang on, yet at the same time what others here are saying about the tee allowing the excess fuel bleed off makes sense too. However (no offence to those who disagree with zmpolartech) given that I can't seem to stop my overflow problem I'm going to have to agree with your comment as seeing is believing and I suspect the uphill push required to return the excess fuel to the tank may be more than is required to push the needle off the seat, even though the hose is larger. So my plea for advice is as follows: I’m running a 38mm PJ which has the intermittent overflow problem (as well as an idle issue) so I’ve ordered a new 38mm Air Striker to replace it. So, this “inlet needle” you are talking about, is it something that can be bought and added to the carb I ordered, or is it cast into the carb body? I seem to recall the PJ seat is part of the body and looking at drawings of the Air Striker I don’t see a removable seat like the Mikunis have. I’m also thinking that if I can’t make the change then perhaps I can run a longer fuel line to the carb and route it so that it offers a little more resistance, or put a valve in it to restrict flow. Any thoughts? Also if anyone is running a standard 38mm Air Striker from a dirt bike and a fuel pump with or without problems please chime in. I’m going to try calling Sudco today to see if they can tell me something about the inlet sizes.
    Tucson
    1,652
    Im running 38's on two of my z's and they run perfect, one of the Im running a brass T with a bigger return outlet which will allow more fuel to return to the tank! The for other one is factory T with no problems ..
    Dec 2007
    Southwestern NY
    517
    inlet seats are pressed in to the keihin carbs and are non replaceable. I know that some people have had some success running the large inlet needled carbs, but it WILL eventually cause a problem (when running the stock-T or one of ronnies billet Ts). A large brass t with equal size nipples all around, should solve the problem (the way badass350x is running them). But what I am telling you is true...I have seen first hand what CAN cause some severe headaches.
    SAY IT!!!!!
    Mexico
    9,014
    Yep, I'd rate massive dead patches of lawn and running out of fuel after 30 minutes of riding in the headache catagory. Thanks!
    tippmann's Avatar
    Nov 2005
    161
    Loll ok goodto know !
