Results 1 to 8 of 8
Thread: trx 250r sliencer on 85 atc 250r
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    i dont have either in front of me at the moment but the suspence is killing me lol
    does anyone know if an OEM trx250r silencer will fit on an 85 atc 250r ? thanks
    84 200s almost done
    84 atc 70 project
    OH
    87
    i put a trx silencer up against the 85 im rebuilding a few weeks ago its pretty close looked like it just needed a spacer on the mounts . The bend looked close to the same. I used a fmf silencer im not sure how stock would work.
    OK
    5,450
    I'm using a Klemm Research trx250r silencer on my 86 atc250r.. It doesn't fit perfect but it fits
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    NEPA
    7,051
    Ditto,,,they are Not the same,,but can work..
    na
    5,702
    I ran one on my wifes ATC for about 6 months. Just run a longer bolt in the back and some shims..This actually is better in the sense, that if you bottom out your shock on a jump, it is spaced far enough over that the brake caliper won't dent the silencer.
    Proudly NOT a member of
    "Team on the Teat"
    Nov 2009
    Okauchee, WI
    555
    I'm runnin a trx FMF poercore on my '85r, longer bolt and a 1/2" spacer on the rear mount.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Oct 2006
    Wickliffe, KY
    125
    What Mosh said, they do look the same just a little different bend in the pipe. I cut a 1.5" spacer from stainless tubing and just used a longer bolt. It looks custom! LOL.
    Feb 2009
    greentown PA
    389
    Thanks for the information :-) !
    84 200s almost done
    84 atc 70 project
