hey guys i have a 2000 f150 2wd with the 4.2 motor and a 5 speed when i push the clutch it i get pressure but its at like 3 inches from the floor ... also when i put it in gear and let the clutch out it doesnt move at all while running you can shift through all gears with out putting the clutch in ... the little window you can look to see the slave cylender, when i opened it i found a huge mouse nest time for new clutch and slave ? any pointers apreciated , patrick![]()
