Thread: 1984 200m glowing red header
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Well ive got a new project pretty well complete, ive got an 84 200m engine stock bore AND IT DONT BURN OIL in a 87' quadsport frame.
    It runs so well, spark plug is tan but after only minutes of riding the whole header turns glowing red ( header is a crf230f).
    Unsure what would do this, is it out of time on the pulse rotor or on the cam itself?? Exhaust is free flowing, no obstructions, clean air filter...
    Oct 2006
    Wickliffe, KY
    125
    Sounds like the cam chain/sprocket is one tooth off. I wouldn't run it any more till you get it fixed. I did the same thing on my first 200x engine years ago. It cranked right up and I took a little spin around the yard at dusk. The head pipe was glowing cherry red! Just had the cam off by one tooth.
    Nov 2010
    446
    Alright, i'll give it a look over, i absolutly hate how the flywheel is tucked in from the timing window ~!
    Sarnia, Ontario, Canada
    3,415
    Timing is timing..
    Could be the ignition timing also..might as well check both.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
