Results 1 to 13 of 13
Thread: Big red dies.
    ATCcountryboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2011
    South-bama
    240
    Big red dies.
    Hi, my 1985 big red 250 doesn't want to idle. It has a very hard time starting as well, it idles a little better once it gets warmed up but it still dies after a few seconds. Could it be the carb, running too rich ect..? Thanks
    1. 1986 bigred 250(the huntin' rig)
    2. 1985 bigred 250(the workhorse)
    4 wheels? Sounds to safe.
    Oct 2007
    Minneapolis mn
    4,067
    More than likely its the carb...
    Hampton, Virginia, C.S.A.
    2,664
    have you tried adjusting the idal? there is a little black knob on the carb that you can turn to adjust it..could be as simple as that..maybe time for a carb rebuild as well
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mexico
    9,018
    I have $5.00 on dirty pilot jet and/or other carb gunk. Check your fuel filter and air cleaner while your at it.
    Mountain Home, AR 72653
    500
    Hard time starting....... Dosen't idle cold....... Idles a little better warmed up.......
    Classic signs to me of a valve adjustment. Have you ever done one to that bike? If not I would do that first thing.
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    Lauderdale County, Alabama
    2,029
    When dealing with something old, anytime you have fuel problems it's normally safe to assume it's something to do with the carb. Pop the bowl and spray her out, reassemble, and ride.
    El-Ca, I'll see your $5 and raise you $10!
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Chazz of Blades View Post
    My money is on El-Cam, bandaid fixes never work!! This is more than just crap in the bowl..if you are gonna do something, do it right.
    The youngsters alway want to shortcut!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    500
    OK who wants to take bets.........
    I bet it's the valves, I have seen this multipal times before. Got a great deal on my son's 125TTR because of a 15 minute valve adjustment. And the way he is explaining it is EXCATLY what was going on with the TTR.
    When went to buy the bike I cranked and cranked to get it to start, and the finally it went. Then If I didn't keep my hand on the throttle it died. Than more kicking to get it to start. I was wise to this situation from some friends of mine who have slightly older kids who have bikes. So I offered a little low on the TTR because it wouldn't start and the owner was positive it needed a full carb rebuild. So I get the bike home, remove the covers and yup both valves are tight. Get my feeler gauges out and readjust them, pull the choke, and whammo bike started on the first kick and idled all on it's own. I told the old owner (which I work with) what I did and how the bike runs, and he hung his head and said guess I should have listened when you guys tried to tell me all this almost a year ago. So I may be wrong, I may be right. But how long does it take to check out my theory????? 5 minutes, 10 maybe. Balls in your court, now dribble it out.........
    @1:45 Thought I figured it out......
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    3,415
    I'd take you up on it '110klt' and you could be right..but it isn't really a common symptom of the 250. Also it wouldn't be a sudden onset symptom but a gradually worsening issue as the valves get out of adjustment..not that 'countryboy' gave us that bit of info.
    Since the 250s have a plunger style choke that always collects dirt, odds would give you that this is carb issue on this particular machine!!!
    But if you really want to give away your money...???
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Dec 2011
    South-bama
    240
    Thanks everyone, I think its the carb from the info that yall have given me. I will see what I can do about it, and I will let you know if any other things come up.
    Mexico
    9,018
    Quote Originally Posted by 110klt View Post
    For reasons I don't have time to get into I'll just say "No way Dude!"
    2,029
    Quote Originally Posted by dougspcs View Post
    Maybe I wasn't clear, pop the bowl, spray out the jets, reassemble. Who would be dumb enough to just try to clean the bowl?
    Nov 2010
    Oshawa, On, Canada
    2,123
    I have nothing to add to this thread because the answer has been stated, but, i love run rabbit run, so thankyou.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
