Results 1 to 8 of 8
Thread: Has anyone ever used a manual type impact driver?
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    I dont have the money for an electric or air type driver right now, and I was wondering how the manual type would work so I could get my Idle gear off to replace my leaky tri-z crank seal.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    wolfspider's Avatar
    wolfspider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    HARROGATE, ENGLAND
    376
    idle gear?
    can you put a rag between cogs to jam them and then undo using regular wrench? just a thought.
    i used a 12v wheel wrench for mine it was about £20 should be available in the states.
    HONDA ATC250ESJ 1988
    HONDA 250R `85 restored SOLD
    HONDA ATC 350X `86 restored SOLD
    HONDA ATC 250ES `87 SOLD
    YAMAHA YZ100 `80 project
    HONDA ATC350X `85 PROJECT FINISHED
    Central PA
    1,952
    Hey another thing, when I had my clutch cover off, my shifter pedal lost its clicking, and its return, and someone said something about the shiftfork coming off the shift star, can I fix that without taking the clutch basket off, because that is what I am going to have to use an impact driver on.
    PastRides
    SOON MY PRECIOUS!
    Rittman, Ohio
    6,276
    The shift shaft probably just got pushed out. The side case holds it in. Push the shift shaft from the shifter side into the motor, and when it moves freely, look in on the clutch side at the other end. There is a spring with two legs hooked to the end of the shift shaft. Position it so the knub on the shifter is in the middle of the spring legs, and push it back in. When the sidecover is reinstalled it will hold it in place.
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    I had one years ago and it never worked. It was a cheapy so maybe that's why. It would make me nervous pounding on motor parts with it.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Manual impacts
    I have one that works great, I think the trick is to use one with good quality bits/sockets to avoid stripping, mine was around $25 at Sears.
    Apr 2002
    s.w. michigan
    6,498
    inpact things
    are you fellas talking about the kind that you whack with a to break loose nuts + screws that are to tight for normal removel ???
    john
    Mar 2003
    Australia
    1,919
    They are very useful and I have used it several times on my trike :-D
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
