Results 1 to 15 of 17
Thread: Fu*%$(g allen head screws!!!!
    STL
    3,560
    SO I would like to request that Honda reconsider the use of Allen head screws on the sprocket and brake hubs on the 250R's. I cant seem to free like 5 of the 8 bolts on the rear that hold the brake rotor to the hub or the sprocket to the hub.
    For starters I am looking to just outright BUY a new set of both hubs, does anyone has a pair WITHOUT the sprocket and rotors attached? second, and I need to look closely at this again, but can I just run a normal hex head bolt in place of these damned allen key head screws?! WTF HONDA
    need em for an 86. I needs em soon. Thanks
    Mexico
    9,018
    ??? Socket caps screws (the proper term) ROCK!!! I use them on everything.
    If you have problems try this:
    1. Use Metric keys, not "almost the right size" Imperial keys.
    2. Try tightening them before you try losening them, as it will often break them free.
    3. A straight whack with a (and I know you have one of those for every day of the week) on the head before trying to move them can help as well, just don't get nuts and bust something.
    4. Heat works on these too.
    5. Always put a dab of anti-size when using a stainless bolt in an aluminiun thread.
    6. When using loctite use the blue, not the red if you ever plan to take the bolt out again.
    Jason, I put a little heat on them threaded portion, seems to help.
    As soon as you feel the wrench doing nothing, take a larger size hex wrench and grind it to a bit of a taper so I can SMASH the key in there.
    That usually does it
    Good luck bud.
    Mountain Home, AR 72653
    500
    I do tend to agree. Socet head screws ROCK...... Used them when I built my 383 chevy stroker, never had trouble.
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    Mexico
    9,018
    Quote Originally Posted by 110klt View Post
    Amen Bro, they are a God send when compared to those Philips head bolts that most Jap bikes come with. I've never figured out how they make them so soft, but I think they have a 15% margarine content.
    Aug 2010
    Southern Oregon Coast
    932
    I'm pretty sure those have loctite on them. Lots of heat is the key...
    Jul 2011
    Eau Claire, WI
    1,188
    El Camexican. I hate to break it to ya bro, but there is NO such thing as a socket cap screw. It's a hex bolt or hex screw. Thus requiring a hex key aka Allen wrench. Sorry bro.
    NOOOOOOOOOOOOOOO, there are allen bolts called a flat head tapered socket head cap screws; 82 degrees.
    I believe he has tapered screws he's trying to get out. They clear the sprocket and caliper.
    Jul 2011
    Eau Claire, WI
    1,188
    I stand corrected.
    May 2011
    eden,ny
    3,481
    I have had my issues with the flat socket heads myself. The taper is what gets locked up. when all else fails I drill a small pilot hole about half way through the bolt,then use a larger drill size (5/16) for an 8mm bolt drill until the head spins off. Then spin it out with an easy out. they usually come out with almost not effort.
    Mexico
    9,018
    http://en.wikipedia.org/wiki/List_of_screw_drives
    Interesting reading for the morning coffee. Seems you can call a bolt that accepts a hex headed wrench (AKA Allen wrench) a few things. The term Allen bolt always irks me though and makes me think of people that call all snowmobiles Ski-Doos
    Bottom line is that young Jason needs to break the crud, Loctite and tension on his bolts and heat and proper fitting wrenches are the key as has been stated. I'm going to put a post up on this subject.
    STL
    3,560
    hahahahha this got out of hand to say the least! Thanks for input guys, I am searching for a set of hubs to buy. My impacts are just spining the screws at this point; the nuts are locked onto the screws which are free in their holes. F THIS, im throwing my brake rotor and hub in the trash! ok not really just frustrated with it! I have a new rear rotor to replaced the cracked stocker with and want t do it asap. I have new sprockets to install too :*(
    I was really looking to see if there are alternatives to these screws, like say a comon house hold BOLT hahahaha I think I need to find a tapered sleeve that will fit into the sprocket and rotors. I havent looked closely but I assume they need to be centered using those 'allen bolts'.
    Mexico
    9,018
    Help for next time is on the way....
    STL
    3,560
    ??????? como?
    PA
    3,515
    The problem with the sprocket bolts are that some guys seem to try to tighten/loosen them buy the bolt head. The smart way to attach is by tightening/loosening by using the 17mm nut and just use the bolt head to keep the bolt from turning.
    Rotor bolts are super easy IF they have not been messed up by someone not using the correct method of removal. I always use my air gun to remove/install these little suckers and have never ruined one.
    WWW.HREATV.COM
