Results 1 to 8 of 8
Thread: '85 250r clutch installation ?
    Nov 2009
    Okauchee, WI
    555
    I'm putting an '85 250r engine together. I have the clutch installed, but I can move the basket just a bit on the shaft. Looking at the diagram in the manual I have it together properly. Just can't remember if the whole assembly should move horizontally on the shaft. Thanks, Matt.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Oct 2006
    Wickliffe, KY
    125
    I just did this last week and can't remember there being any play in the basket... I'll have to look at my spare clutch but I believe there is a washer behind the basket then a washer, the lock (bendable) tab and then the nut in front of the basket. I put the nut on with and impact and I'm sure there was no play.
    Nov 2009
    Okauchee, WI
    555
    The clutch center (witch holds the plates) and pressure plate do not move. The basket witht the attatched gear move a bit. They both seem to spin independently from each other. Been a while since I've had this engine apart, just can't rememder. I would hate to get it all together and installed and not be right.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    NEPA
    7,051
    It's an engine. You should have no play. Recheck everything for wear,or a missing washer. 1 or 2 mm off in these will break them : )
    I think your missing the thrust washer that always gets stuck to the back......
    Nov 2009
    Okauchee, WI
    555
    I have the thrust washer that goes between the basket and clutch center. Also the one on the end with the locking washer and final nut.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Nov 2009
    Okauchee, WI
    555
    Yup, they're all there. 16 and 20 too. Possibly a worn basket? Got me stumped. This is a spare engine I was planning on selling to a buddy, but now he will have to wait. He's not in a huge hurry, but it'd be nice to have it finished while I have the time to do it.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
