I just put a new battery in my atc 200es big red and was thinking, will my battery run a small atv winch? I had a great idea for a mount. Whatcha all think???
Yes it will run a small atv winch just fine.
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
whats your idea for the mount
1984 Honda 200M
1984 Honda 200M
1996 Yamaha 250 Timberwolf 4x4
1990+ Xingfu Hunter
1986 Suzuki SP200
answer given is correct.
________________
https://www.mikesatvfix.com
I can't tell how it's mounted: But, as long as you mount to the forks or any other portion of the trike chassis, you'll be fine.
Enjoy![]()
That looks great! Did you make that mount?
I've heard that regular 12v lawnmower batteries fit in the 84 200 es trunks
if you happen to need more amperage.
Question........ What will you use it for? Do you do alot of mudding?
1984 Honda 200X
1999 Kawasaki Bayou
2000 XR 200
where its connected to the forks looks a bit weak to me
1984 Honda 200M
1984 Honda 200M
1990+ Xingfu Hunter
1986 Suzuki SP200
I can use the pooh out of the winch, and still havent tweaked the forks... I could pull the whole machine off the ground into a tree, and it still wont move... (I mud, and it runs my plow too) Even works well for pulling my buddies Outlander out of the mud when he breaks a CV joint
