I got a 86 200x motor I was rebuilding got it all done ran good but it started smoking but I never replaced the valve seals even thou I should of but now I been hearing a hissing noise and it's coming out the carb then when the engine is off I started to take the the oil cap off theres a lot off pressure in the crank case as you start to unscrew the oil cap I'm not sure if that's normal?
