Results 1 to 9 of 9
Thread: can't unblock fuel intake on carb
    Apr 2012
    Toronto Ontario Canada
    30
    Hey everyone, I have a mikuni VM 22 Carb from my 1985 225DX and I can't seem to unblock whatever is inside the fuel intake pipe, or something further inside the Carb. I've tried spraying Carb cleaner inside however it just shoots back out at me. I've also tried using compressed air which was able to get some of the crap out, however the pipe still isn't clear. Any suggestions of what I should do now?
    Jul 2011
    Eau Claire, WI
    1,188
    Use a probe.
    6,813
    Try blowing it out from the other direction from the float valve . Let it soak if you need to .
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    i would use a drill bit and turn it with your fingers to drill the crap out
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
    Aug 2011
    Sacramento
    41
    Post a picture. Maybe that particular passage isn't what it seems, and if someone recognizes that carb they can confirm whether it should be clear.
    Apr 2012
    30
    I was able to unclog it, had to take off the bottom of the Carb, take off the float and then used compressed air in the cable where the small pin attached to the float goes. Hopefully it'll start now!
    Aug 2011
    Sacramento
    41
    Good deal. Let us know how it worked out.
    Apr 2012
    30
    Will do, still waiting on an o-ring and a gasket but once they come in everything should work
    Apr 2012
    30
    just picked up and installed the new starter set and gasket on the carb and what do you know the thing started right up right away, all seems well now
