Results 1 to 14 of 14
Thread: Machine shop ruined my head!!!!!!!!!!!!
    Apr 2006
    Crestview, Florida
    2,429
    I picked up my 350x head from the machine shop the other day and when i was putting it together i notice they had blasted the cam journals! I was just finishing up my 350x motor and fired it up to find it tapping real loud. I am pissed and im sure out of luck. This old man i can tell is very stuck in his was and will never admit he did anything wrong. I may just drive by his shop and sling the damn thing through his window.
    Rides
    85 ATC350X
    85 ATC200X
    Visalia, CA
    720
    Quote Originally Posted by Erics350x View Post
    Well too save that head I would guess you could get a oversized double roller bearing cam from mega cycle.
    Thats what I would do or you could figure out some way to put some sort of a bushing in there.
    "Your 4 wheeler must be fast because you were haulin' ass....UNTIL I passed you on 3 wheels"
    RIDE RED......OR RIDE HOME
    TRIKES ARE NOT DANGEROUS......IDIOTS ARE!
    RIP
    NOS_350X is the most bad-ass person in the world
    Jul 2011
    louisiana
    55
    I got one that's sand blasted no valves or anything you could put your parts in pm me
    Thats a shame. Apparently he doesn't know what cam journals; I guess you should have taped them off or educated him.
    Unfortunately allot of guys need instructions......
    EDIT- What was he supposed to do? just shave off a few thousandths because it wasn't flat??
    Regardless, that suks; Good 350X heads are hard to find for a reasonable cost......
    Nov 2008
    ontario
    1,055
    Take it in and throw it at him make sure he never touches a part again any machinist should know that
    proud owner of a trx300ex quad and an 85 atc 70
    Apr 2006
    Crestview, Florida
    2,429
    The sad part is that the head was fine before. I was just goin through everything while I was installing the new piston, cam, ect...
    Rides
    85 ATC350X
    85 ATC200X
    So cylinder wise; He was boring it and blasted all the stuff?
    Why did he even touch the head (unless was seating/changing valves)
    Sorry to hear bud.......
    May 2007
    Orange County, NY !
    1,672
    You can go back to him with a witness and it's all in the way you ask him, you can get him to admit he ruined it. Then tell him he wasn't supposed to do what he did.
    Apr 2006
    Crestview, Florida
    2,429
    Im gonna see what he says, all i can do. He was just suppose to check everything and throw in new valve seals. I think i have another one hid somewhere if i didnt trade it off.
    On another note, I just tossed on a 37mm FCR carb and man this thing is a beast. Went from bone stock to a bunch of modds all at once. I can't wait to get it riding again.
    Rides
    85 ATC350X
    85 ATC200X
    Mar 2007
    Texas
    5,045
    if he was not supposed to blast it, then he was dead wrong for doing so. cleaning is one thing, but blasting should never ever happen unless discussed. there's a good chance, he screwed soemthing else up and blased it to hide the evidence.
    ________________
    https://www.mikesatvfix.com
    glendive, montana
    1,822
    they do make a flapper wheel sander that might be able to clean it if it's not blasted to bad and you are able to clean it up with light pressure, otherwise he destroyed the original journals, and unles you oversize with custom races or do an oversize cam it's toast, sorry to hear what happened I hate careless machinists. O r about the idiots they have working for them.
    I'd put the cover on the head and use a small hone, (like for caliper honing) Then just measure it up and see whatccya got!
    He didn't blast it with rocks? did he?
    malibulvr's Avatar
    malibulvr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Lockport, NY
    203
    Wheel cylinder hone, that may just do it but not sure what the finish is supposed to be. Good luck
    Keep the drill on low and just barely have some pressure on it You really have to in and out quickly and not affecting the finish'
    Hones cross hatch for a cylinders is about 30 degrees.
    I bit harder going in and out of a caliper
    I have just cleaned the grooves with a sharp pick and then just went in and out to those same degrees. Your other option was what we use to do, get some WD forty, clean it out an just clean it up cylinder.........................
