Washer Goes Where???
I got a ATC200ES question...
I had to tear into it to replace the starter clutch behind the flywheel... There is a needle bearing that the starter clutch gear rides on, but there is this washer, the parts diagrams online show this washer on the outside of the starter gear, between the starter gear and the flywheel, the service manual mentions a spacer that should be placed on the crankshaft before the gear and needle bearing. Since the two source of info don't agree, and i honestly don't remember the order in which it came apart, which side does this washer go?? To the engine side of the starter clutch gear, or to the flywheel side of the gear?
//ArrowChat Integreation Code
