Thread: supprised i haven't came into this sooner 250r woes...
    Deathrocket's Avatar
    Deathrocket is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Assachusetts!
    349
    went to do crank seals on my 81 250r and the collar between the crank gear and bearing is pitted might explain why its not running right, air leak at the seals, I need to find one but honda doesn't make em anymore, cant seem to find em on ebay either. anyone got any suggestions? and what if the crank is pitted on the other side? then what? do i have to split the case and refurbish the crank? what do i do?
    Have a machinist make a collar if need be. The crank can be welded and turned (I think), but I seriously doubt there will be much damage to the crank itself.
    connecticut
    59
    To add to Fabio's idea, the crank can be turned down to remove the pitting and a use a smaller seal if it can be located. There may also be plating options to bring the crank back to correct diameter for the stock seal.
    Assachusetts!
    349
Name:	crank collar.jpg
ID:	147412 this is what i need.. anyone got one? the spacer is only pitted a tiny bit, but its right on one of the lip seals of the crank seal, so hopefully I don't have to split the case to do it..
    Assachusetts!
    349
    oh yeah, the machinist thing did cross my mind, that is the last case senario, as it would probobally cost at least $100 if i had to have it made. when i know if i can find a used one i would be looking at 20..
    Connecticut
    1,605
    Worst case scenaro if he collar is not pitted too deep can you possibly rub JB weld on it and sand it smooth?
