Results 1 to 15 of 21
Thread: no neutral on sx
    stillhunter's Avatar
    stillhunter is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Port Perry Ontario Canada
    180
    no neutral on sx
    talk about a crap weekend ,jack stand collapsed dropping the van on my foot putting me out of work for 6 weeks.Then I was going to use my sx to get around the property but its stuck in gear won't go into neutral.Any thoughts on the sx Ive heard plenty about the foot ha ha
    Nov 2010
    Oshawa, On, Canada
    2,123
    You mentioned at Ganny that you're shifter gets stuck down.
    I bet the # 21 return spring pin is broken. I just fixed my sx a few weekends ago.
    gasket and the pin ran me 23 bucks, easy fix!
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Apr 2010
    180
    That's what I am hoping ,Where did you get them? And ya it did it at the Ganny and was fine since.Had it up north last weekend with no problems, went to unload it today and its stuck.I'll pull the cover tomorrow not like I don't have time
    Lay it on the rt side.
    Remove starter reduction gears and take the cover off thats over the light coil etc etc.
    You will find a broken/spring/boss/pin -literally, I'm fairly confident it will be staring at you.
    NEVER EVER EVER remove the 3, 6MM or 8MM(??) allen head bolts holding the output shaft.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I bought them from my honda dealer in havelock.
    Pop the cover, pull out the shift shaft, and you'll see a broken pin. Should be sitting in there nice and loose so just spin her around with a screwdriver.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Howdy's Avatar
    Celina, Ohio
    10,079
    Sorry about your string of bad luck. Does the sx shift into all the other gears ok? If it don't shift right in the other gears there is a good chance either the shifting locator "pin" ( 24652-HA0-000 ) came loose or broke, or the "arm, gearshifter" broke ( 24621-HA0-010 or 24621-HA0-020 ).
    Howdy
    Apr 2010
    180
    Thanks for the help guys,I'll pull the cover tomorrow and check it out.The shifted had been a little bit fussy not always returning without a little nudge.
    Apr 2010
    180
    Pin #21,will try and find Honda dealership today .Thanks again guys
    Apr 2010
    180
    Ok pin #21 was broken.Changed it, still no neutral,goes up and down one gear ,actually might only be one gear think its stuck there.Seems like its all locked up.Rode it at the trailer then fired it up and loaded it to come home,was fine ,now this ,brought it home with parking brake on, it must have got knocked into gear.Any more help would be great
    Apr 2010
    180
    checked everything else on that side ,seems fine,any other ideas
    Thats when I support the rear end and have a friend roll them while you shift up and down and watch the shifting mechanism and try to see what the issue is. This is very common, my SX did the same thing. Almost never an internal issue......
    Apr 2010
    180
    rear wheels don't move at all
    Apr 2010
    180
    Ok, decided to check rear brakes, they were jammed up ,freed them up and got all gears back. Problem now is the neutral light won't come on. The reverse light does but not the neutral. As I said it goes.through the gears with no problem wheels spin freely in neutral any thoughts?
    It grounds near the brake lever; It gets contaminated and loose.
    Apr 2010
    180
    Ok I'll check that, is there anyway to bypass the neutral safety to get it to start with the kickstart
