Results 1 to 15 of 16
Thread: 1984 kawasaki tecate parts bike
    May 2012
    San Diego CA USA
    98
    Since I can't post in the other sections I wanted to share with you all what I have to offer in here. Parts for an 84 tecate including engine with good compression, stock pipe, radiator, carb, cables, axle, good shock, set of original dunlops and rims, no wiring or stator...only one of the forks. A little surface rust but all parts usable. Message me.Click image for larger version.
ID:	147575Click image for larger version.
    May 2012
    washington
    do you have a decent flywheel?
    May 2012
    San Diego CA USA
    98
    Heh well it would work if you glue the magnets back and soak it in rust remover.
    Apr 2012
    coshocton
    159
    good parts bike
    Aug 2010
    Southern Oregon Coast
    932
    Quote Originally Posted by nonesense View Post
    Get hold of Jeswinehart. As long as the magnets aren't chipped or broken, he can fix them up like new.
    mine before:
    after:
    Apr 2002
    s.w. michigan
    6,498
    Quote Originally Posted by falloutboy View Post
    mine before:
    after:
    Thanks Mark. I bought the flywheel nonesense has, along with a few other parts for a very resonable price. I'll see if I can save another
    May 2012
    San Diego CA USA
    98
    Nice doing business with you ask around if anyone needs that motor and Carb.
    May 2012
    San Diego CA USA
    98
    I still have this junk bike guys...
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    Do you have a coolant bottle?
    Jun 2012
    pa
    292
    Quote Originally Posted by tripowersport View Post
    Or kill switch? thanks.
    May 2012
    San Diego CA USA
    98
    Neither of the tecates I own have overflow tanks for the radiator if that's what you mean. Yes I have a good kill switch.
    Jun 2012
    pa
    292
    how much for the switch shipped? My one tecate leaks a lil out the over flow when i'm on it, And the coolant will go down to the fins, do you know why? Thanks.
    Jun 2012
    pa
    292
    I was told its was a race trike in the 80s, there is a 400 or 500 sleeve in it, ported and polished, Boyesen reeds and a race pipe. I Put in new Clutch, rings,gasket's with seals etc.
    May 2012
    San Diego CA USA
    98
    I would drain the coolant and put in what the service manual suggests, make sure not to overfill, antifreeze expands when hot thus the overflow. $30 will do it for the switch.
    Nov 2020
    San Bernardino
    How do I get ahold of this person to do my flywheel
    mine before:
    after:
