ATC 110 Motor Rebuild
Hey everyone...new to this site but looks like it is a wealth of freakin' knowledge! Due to that, I'm here to learn.
I love tinkering in the garage and picked up a 110 ATC to keep me busy. It was in pretty rough shape so I have completly broken it down. It is a learning process and I am ready to give the motor a freshening.
I am kind of at a loss for what parts I need. I measured the piston and it is right at 52mm. The clyinder wall is smooth so I do not think it needs to be honed. I'm assuming that I can just get a new set of rings for the piston. Do I need just 52mm rings? When I went to DRATV.com to look at what to order all I saw for rings was:
STANDARD__(75D) .25MM/.010"__(75B) .50MM/.020"__(28K_rings
Is it the .25mm one that I need for a 52mm piston?
Or maybe I should just order a new piston and ring kit for 75 bucks and call it a day.
Also...any good recommendations on a top end gasket kit? I also need a valve seal kit too I think.
Thanks everyone
Mike
//ArrowChat Integreation Code
