Results 1 to 10 of 10
Thread: Lack of power at high rpm??? HELP
    May 2012
    Quebec
    10
    Hello, I got a 1986 Big Red 250ES and i was riding it few hours ago then sundently it lost all his power, It's still running fine at low rpm but when i rev it up it take alot of time to reach higher rpm and doesnt have any power, Im pretty sure it's fuel filtrer but my dad's think it's carburator so please help me
    BTW: Where is located the fuel filtrer on those machine?
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    there is a fuel filter in the sediment bowl in the fuel shut off valve
    May 2012
    Quebec
    10
    Quote Originally Posted by torque View Post
    But what do you think it is?? Fuel Filtrer or the carburetor
    May 2011
    iowa
    41
    It's starving for gas in the upper rpms, it's a process of elimination, start at the tank and work towards the carb...when you find the problem tell us.
    Oct 2007
    Minneapolis mn
    4,067
    carb... Primary nozzle or main jet is likely plugged... Good time to rebuild the carb. (rebuild, not just clean IMO)
    May 2012
    Quebec
    10
    Well my carb had a rebuild 1 month ago and it was running fine after it
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    it will take ya 2 mins to pull the filter out and clean it. what does the inside of the tank look like. if it is full of rust could be your problem. just some simple advice.
    fingerlakesny
    2,834
    i have a 250es with a rusty tank but i run a in-line filter and havent had any problems... after cleaning the carb , so i would reccomend the same...
    May 2012
    Quebec
    10
    So far now i have checked the air filter, The fuel filter, Changed the spark plug but i still have this problem but few hours ago i had a discution with the local atv dealer and he told me that he already seen that problem, The thing is that the cover of the spark plug ( That i dont know the name in english ) Must be at his end of life, So this cause a bad fire, I'll change that tomorrow and tell you about it!
    May 2012
    Quebec
    10
    Finaly found the trouble! The screw that hold the carburetor piston was missing , So the piston was now able to go up !
