Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Looking for a torch and need some help
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    It is time I invest in a decent torch but I know little about them. I have used them quite often for cutting and brazing but it has been years since. Plus, I did not really know much about them then other than how to use one. Now the time has come for me to start saving up and getting the stuff I need. This is not a tool that I will use daily so I doubt I need the finest and most expensive stuff out there. I do want full size bottles however. So other than the bottles and cart what should I look for? I have heard both sides of buying new and used so what is the real story? What is wrong with buying used stuff? I know I have to stay away from used hoses if they looked cracked and aged. What brand should I look for and what type of maintenance issues should I be aware of? Should the regulators match the rest of it brand wise? What type of gas should I use? I have heard that acetylene is no longer the best to use. I will use it for cutting (all kinds of metal), brazing, (again, all kinds of metals) and heating metal for reshaping, loosening fasteners, and so on.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    May 2011
    eden,ny
    3,481
    things to check for on a used outfit.cracked o'rings diaphragms in the regulator (just make sure they work) cracked or burnt hoses.brand matching is not a big deal just avoid anything with a made in china sticker on it. I recommend using a torch head that takes victor style tips since they are easy to find. Some of the other types can be a nightmare to find.I use propane only because I had only one gas cylinder and didn't wanna buy another and I already had a couple extra gas grill type propane cylinders. You just have to change to a propane tip. You are also suppose to use hoses approved for propane since the acetylene hoses will deteriorate over time but will take ten years for that to happen. also if you get used tanks make sure that they can still be filled or exchanged. edit... you won't be cutting too many types of metal with a torch set up. if you want to be able to cut stainless or aluminum you will need a plasma cutter but you can't do any brazing or heating with that.
    Jan 2005
    5,301
    Is propane cheaper to fill? Are the tips and hoses cheaper and do they have the same or better life span? Also, how does propane compare to acetylene with comsumption? Will one use more or les to do the same job?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    9,019
    "All kinds of metal"? A flame torch will only cut ferrous metals (carbon steel). If you want to cut non-ferrous metals you need a plasma cutting machine which does not have a flame per say so you can’t heat with it.
    I’d spend the extra money on a Victor kit. They aren’t that much more and you’ll never regret it. Everyone makes spare parts and accessories for Victor torches as well. There are some cheap kits out there and as someone who has gone to China to do Q.C. on them I can tell you they are hit and miss. I never found a factory that I was comfortable with dropping a P.O. on. If you do go that route (Made in China), buy it at a reputable welding shop and keep the receipt.
    Make sure you have flash back arrestors installed at the torch. NEVER oil your fittings, don’t even touch the threads with your bare hands. Always open your oxygen bottle all the way and only open your acetylene bottle one turn. Always shut the valves when not in use. Keep the bottles vertical when in use, especially the acetylene and if you have to lay the acetylene bottle down be gentle, say thing when lifting it back up.
    Always tie your bottles up, or store them in a good cart. Use the proper wrench to tighten the fitting (spend the money on a wrench), don’t use an adjustable wrench. Check for leaks with soap and water.
    As far as better gases than acetylene goes I know some are more economical, but I like acetylene. Maybe it’s because the rigs I’ve used with other gases weren’t set up right, but I learned with acetylene and I’m sticking with it.
    May 2011
    eden,ny
    3,481
    propane is cheap if you have the tank refilled,the cylinder exchange at gas stations ect. is a rip of IMO but is conveinent in a pinch. If you run the gases at the same pressures the consumption will be the same. but propane can be run at higher pressures. The propane hoses are more expensive.I didn't bother getting them I just used the hoses that cam with the kit since the hoses will probably need to be replaced because of too many repairs before they will wear out from using propane.
    Jan 2005
    5,301
    I used the ter all kinds of metals as a just in case thing. I never know what kind of projects I will get into. That was a lot of good information though. You summed up some of the things I was wondering.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Jan 2005
    5,301
    Quote Originally Posted by just ben View Post
    Thanks for clarifying.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Just so you know, you technically CAN cut stainless with an oxy/acetylene. It is not easy, and the results are not pretty, but you can cut it if you have to. Probably more on something that you're just trying to rip apart and really don't care about. Just throwing that out there. I've used oxy/acetylene for years but it's never my own setup. I bought an old used setup at a swap meet a few years ago but I've not used it yet.
    Ben, how does the propane compare to oxy/acetylene as far as cutting and heating things goes? I didn't know you could do those things with propane. I'm very curious about this.
    Jan 2005
    5,301
    Welding and cutting SS is something I eventually want to do as well.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    9,019
    [QUOTE=fabiodriven;1130690]Just so you know, you technically CAN cut stainless with an oxy/acetylene. It is not easy, and the results are not pretty, but you can cut it if you have to. Probably more on something that you're just trying to rip apart and really don't care about. Just throwing that out there.QUOTE]
    My experience with attempting to cut SS with a flame has resulted in more of a "melting" effect rather that cutting and yea it can be done, but YUCK!. Something to do with there being no iron content in SS. Did you know that you can cut thick steel with pure oxygen? Once the steel has enough heat in it (thats what the gas is needed for when cutting) you can shut it off and cut with just the O2.
    Jan 2005
    5,301
    I would like to see that.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    May 2011
    eden,ny
    3,481
    as far as cutting I see no difference . as far as heating propane can actually heat better depending what you are doing since you can use a bigger rose bud becuase of the higher pressures you can run. If you try to run acetylene at higher pressures the compounds of the gas separate,Thats the reason for only opening the valve 1/4-1/2 turn. I used to know alot more about all this but not doing it on a daily basis for work in the past 10 years I forgot alot of what I knew
    9,019
    Quote Originally Posted by LonesomeTriZ View Post
    Best bet would be at a steel mill that cuts billet. It needs to be heavy (like 4"+) and I don't think the human hand is steady or smooth enough to pull it off.
    Re: Welding SS, if you can weld carbon steel you can weld SS, but rod/wire selection is critical. You need to know what your base materials are as there are many kinds of SS and they need specific rods in order not to crack when welded. For most SS to carbon steel connections you'd use 309 SS rod/wire and the standard 304 SS to 304 SS uses a 308 rod/wire. The local weding shop guy will be able to set you up, but you have to know what you are welding before you ask. (your polarity setting may be different as well on a stick machine)
    Jan 2005
    5,301
    That is the problem i am having. I learned a lot by doing it all the time. But I have not done it in so long I have forgotten most of it.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Jan 2005
    5,301
    SS and alumun are my goals. I figured if I can cut and weld that stuff well, steel will be easy to master as well.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
