Results 1 to 9 of 9
Thread: Leaky tank
    Kentucky
    511
    Leaky tank
    Will Red Coat fix a leaky pinch weld on a gas tank and will it last? The tank is already painted so I don't want to weld on it.
    Howdy's Avatar
    Celina, Ohio
    10,079
    I coated a tank 5+ years ago that had a 1/8 hole in it. I put tape over the hole and red-Koted the tank. 5+ years later the Tank is still holding and has never dripped a drop. AWESOME stuff!!!
    Howdy
    Dec 2010
    Back in VA baby!!
    711
    MarineTex works great for holes..a little hard to get in there, but it will atlast the tank itself..
    Ripley Tn
    1,363
    could put a spot of labmetal on there and then red coat it and just put a little touch up paint on it
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    Trackburger's Avatar
    Trackburger is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Virginia Beach
    254
    I can attest to Red-kote, the stuff works great. I know most things like this say to use outside or in a well ventalated area, but definitly use it outside... it is some POTENT stuff!!!! Just make sure your tank is clean of any loose stuff (if its rusted) and it has to be BONE dry.
    1985 Honda ATC 250ES BIG RED
    1985 Honda ATC 350X
    1985 Honda FL670R Odyssey ROTAX conversion
    1993 Honda Type II 200
    2003 Honda TRX 90
    2006 Honda TRX 90
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Trackburger View Post
    Yep it does. I rinse all tanks with some ascetone and then blow some dry air in there for 20-30 minutes. The ascetone vaporizes quickly and leaves no residue, this allows for GREAT results when coating. And yes the stuff is VERY POTENT!!! NEVER use it in a closed area. I don't do tanks in weather colder than 65-70 degrees because I am outside doing them.
    Howdy
    Dec 2010
    S.E. Illinois
    1,178
    will have to agree, used it on my 70 tank. tank was so shot i didn't even bother to clean it, both lower edges was like swiss cheese. figured it'd either work or not. my buddy had a little left from when he did his all of his tanks over 2 years ago. smoothed some JBweld on the big holes, painted, then sealed with +2 year old Red-kote. 1 month later and so far still holding.
    74 HONDA ATC 70
    Jan 2011
    Brazil, Indiana
    2,087
    Quote Originally Posted by Howdy View Post
    Actually they say you can thin it with acetone, so it is not necessary to dry the acetone in it before you start.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Kentucky
    511
    I got a can of red coat and the directions said that to not put race gas after red coat is applied. I called them and they said the lead in race gas will mess it up. Has anyone ever put race gas in a tank that was treated with red coat? What is a tank sealer that will hold up to race gas?
