83 110 spark
Got mad that the 110 wouldn’t start. Had Air fuel and spark. Noticed when I would pull the pull start fast the light would go from nothing to bright like it was storing up energy the more u pulled it. So I pushed it to the top of the hill put it in 4th and started rolling down the gill about half way down it finally started. I stopped kept giving it gas to keep it running. Doesn’t have much power in first the engine runs good has a lot of response. Won’t idle I need to adjust the carb. But won’t start now with the pull start. I think its because of a week spark. The 83 has a electronic ignition so if I go into it and clean the contacts I should get a hotter spark it sat for 6 years so maybe it got some rust on the magnets.
I’m sure that it being in High rang would make it not have much power going up a hill it would pull up one but not with tork I’m sure low is better but it won’t switch do u have to switch it on the fly.
1986 200X
1987 250SX
1986 125M
1987 125M
83 110
1978 Ford F350
