Results 1 to 15 of 28
Thread: Tecate dies when warmed up?
    kokmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    Sioux Falls SD
    196
    I gotta 84 tecate that starts real good and runs good but after about 10 mins of riding it will just die. i let it sit and it will start no prob. I think it is a float prob as i have clear gas lin and it doesnt seem to be flowing through. only happens when i let off gas never at wot. carb is stock has dg exhaust and pod filter. I have a keihn pj flatslide that i would like to install but not sure what cable to use to do this with. stock cable doesnt fit? also how does one know if you got your float adjusted correctly just bend tap till gas come out of overflow then bend back little at a time till it stop flowing out of over flow?
    85 Tri-z
    85 Tri-z with Astro Kit
    Jan 2011
    Avon, Minnesota
    641
    find the factory settings and use a feeler to figure the float issue out. they are problay set to low. you can try to just bend the tab a little and see if it helps then you know. but it could also be the cdi or stator since they will make it die when they warm up.
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Southern MN
    1,875
    A couple other ideas would be the vent in the fuel tank cap. Make sure its clear, blow it out with compressed air. If its clogged, the fuel wont flow through the line. Other likely cause would be the coil. Most of the time when a bad coil gets warm, it will not produce spark, or not enough to run properly. Im thinking it wouldnt be a fuel level issue at the float, as it would either run funny all the time, run out the overflow, or run out of gas at WOT.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Mar 2008
    Sioux Falls SD
    196
    shouldnt the gas line basically always be full seems like when i dies the gas line is always empty. coil will be my next step. anyone know what cable to use on the keihn carb?
    85 Tri-z
    Sep 2005
    MICHIGAN
    2,027
    Having ridden with similar issues like dying when hot, my guess is weak stator or electrical problem. What? On a Tecate? Go figure....
    86 T3
    84 T3
    86 KX250
    x2 of what nd4speed said. I've been down that road as well. It's not completely impossible for it to be the coil, but I highly doubt it.
    Ripley Tn
    1,363
    check the top end to for comperson
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    May 2011
    eden,ny
    3,481
    The thing that sticks out to me is you say the fuel line is empty when it dies. as said before make sure the vent on the gas cap is clear an the petcock is clear. I have had a couple petcocks that were oxidized badly and partially block the flow. to eliminate or confirm the stator download the service manual and test it per the manual.
    Mar 2008
    Sioux Falls SD
    196
    yea the petcock is clear as is the vent line. I do have a rebuild stator laying around that i could toss in there. compression is real strong and always starts on first or second kick. only dies when i am coming to a stop and rpms go down. like i said earlier though shouldnt gas line be full most of time. I have never really paid much attn to the line until it started dying. gonna adjust float today. if that doesnt help gonna throw in rebuilt stator. again any ideas on what cable to use on a keihn pj carb stock tecate one doesnt work? I would like to run this carb anyway rather than stock since they are suppose to give better throttle response.
    85 Tri-z
    Sep 2005
    MICHIGAN
    2,027
    I have an inline filter on my gas line and it or the lines never look full of gas.
    86 T3
    84 T3
    86 KX250
    Sep 2007
    100mi west of Chicago
    3,582
    I had a sled that ran like crap when it got warm and it was the stator going out
    Rob
    More than likely the (POS) Tecate, has an ignition part that fails once warmed up........
    Sorry to brutal!
    Mar 2008
    Sioux Falls SD
    196
    yea didnt get a chance to work on it today but am gonna try switching out stator when i get a chance.
    85 Tri-z
    May 2011
    eden,ny
    3,481
    Sorry to brutal!
    point of sale? I agree that the ignition is junk but are great machines otherwise
    Spring, Texas
    450
    Sorry to bring this back from the dead, but as a new tecate owner i would like to know what dirtcrasher meant by POS?! : ) back to topic... My tecate shut offon me a couple times after warm. What would be the suggested fix? Is the ricky stator a viable option? Can a cdi from a tri z work?
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
