So I have been having some real problems with my tri-z transmission. The 6 speed that was originally in tthe bike had a problem with the 1st gear, I didn't have any 86 parts, so I put a 85 5 speed in it. I fully rebuilt the engine, and after about 10 hours, I somehow broke a dog and it bound up and cracked the cases.
So I bought a donor bottom end (85) that needed crank bearings. Today I split the cases at work, and pressed in the new bearings. But....
When I rmoved tthe transmission, the shaft closest to the crank, on the stator side. the small gear on the end fell off. The manual doesn't show which way the gear should be installed, also it had a washer on the end that looks different than the one that was on my lastt tranny, it has 4 little grooves in it. Also the reason the gear came off is because in the manual it shows a small clip to hold it on I think, but my old tranny didn't have the clip either and besides holding it for assembly it doesn't look needed. I can try and upload a pic from my blackberry, but its kind of a pain.
Does anyone know what I'm talking about?
Or is there any pics or ttutorials showing the assembly of the ttranny?
I normallly wouldn't. Ask but the manual really lacks some detail.
