Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: IMPORTANT - 250R Tank - Clark - WARNING
    Tionesta, PA
    5,747
    This is a big heads up. I've never heard of this issue before, and can not believe it is manufactured in this way, but I want to get the word out. I recently purchased an 85 / 86 ATC250R Clark tank. There was a little fitment issue. When I would bolt the front of the tank to the frame, the rear "ear" holes (at location of front seat latch) were about 1/2" off - to far forward. I tried to pull, stretch, pry the tank back so the holes would line up with no luck. So I drilled out the metal bushings, and egged the holes out. Now it fit. I carefully mounted the petcock, and it was then time to fill the tank with some petro to be sure the petcock seal was good. With some pre-mix in the tank, the petcock was not leaking, then a rush of gas started flowing onto the ground. The petcock was off, so I knew it was not from the carb. Low and behold, where I egged out the ears on the back of the tank - gas was gushing out.
    NOTE TO ALL - do not egg out rear ear mount holes on Clark ATC 250R tanks. There is a hollow cavity around the bolt holes!!!!! (this may or may not be the case with Stock tanks, although stock tanks should not have fitment issues as aftermarket tanks may)
    I carefully took my grinder and chopped out a 90 degree notch to expose the cavities around the mount holes at 12 and 3 o'clock and 12 and 9 o'clock respectively (right and left side).
    I now need to find a gasoline resistant epoxy or silicon to seal these holes. Then when I mount that back of the tank it will have to be a "pinch" mount rather than a hole mount.......... What a nightmare!!!!!!!!!!
    Mexico
    9,018
    Has anyone out there ever bought a Clark tank that just bolted on? I know I've never seen one.
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    http://www.amazon.com/SEAL-ALL-2-OZ/dp/B0017M44Q6
    not sure on plastic but this stuff worked good on my old car tanks
    Nov 2004
    Waterloo IL
    2,701
    Do you have any pics of this? I can't seem to picture what you are describing. The rear of the stock tank bolts on through aluminum, are you saying the Clarke tank mounts through plastic?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Oct 2006
    2,504
    I just finished up a 250r tank last night. I assume you need this for TF2012. If you need it I can get it in the mail today......well Mrs. Clean can get it in the mail today!! I also have an oversized tank in the classifieds.
    ONEBAD350X's Avatar
    ONEBAD350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    Iowa
    339
    wow that sucks. Thanks for the heads up. I hope you get it fixed.
    Miami,Fla.(305)
    808
    I have brought this up a here a few times when a 250r clarke tank is discussed. I never got a response or reply with others having a problem ever. Clarke of course says the same. I Had the exact same issue on 2 new white 250r tanks bought a few years back- many months apart. A new tank should just bolt on. I had to modify both tanks (front mounts) to get the bolts to go thru. No amount of prying or pulling would make the holes line up. Not your fault. They don't test fit the final product I guess. And that hollow section around the rear bolt holes really was a sucky idea. Oh yeah the gas cap seal lasted about 2 months before it crumbled into the tank. Also the area where the seal rides against (on the tank) is really thin,-not much sealing area. -I believe the newer CR gas caps fit. Sorry to hear about that.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Mexico
    9,018
    Quote Originally Posted by 3wheelrider View Post
    My oversized Clark tank for my KTM required the following mods to fit:
    - Drill out the petcock filter hole
    - Drill out the mount holes on the stock petcock base to allow it to match the threaded inserts on the tank which were 3/16” farther apart than the stock tank
    - Drill out a crooked petcock insert and re-tap it
    - Grind the stock seatpan mount to allow for the misplaced tab on the Clark tank
    - Install two “dummy” bolts in my rad shrouds as Clark felt it was unnecessary to add threaded inserts in those locations.
    I called them when I realized the petcock was not going to bolt on and got the canned “We’ve NEVER had a complain about this before”
    Aside from that it was a snug fit to the frame, which is fine, it has an awesome oversized fill cap and it looks pretty good, but if you aren’t a do it yourselfer this is not the tank for you. It also covers the radiator bleed screw, so you have to remove or lift the tank with the bike running to bleed the right side rad.
    Dec 2010
    Back in VA baby!!
    711
    MarineTex is what you need...go to any boat store and they'll have it.
    Tionesta, PA
    5,747
    I went to a local parts store and bought JB Water Weld. It is JB weld designed for liquids. Resistant with gas, oil, hydraulic fluid, water, liquids, and bonds to plastic, brass metal, etc. I'll post up later when I see if it holds gas.
    fire1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    Roanoke,Virginia
    404
    Thanks for the info I was getting ready to a order a white Clark 250r tank now I'm concerned
    Tionesta, PA
    5,747
    I have always called my orders in. May try the same, tell them you know folks who have ordered and have fitment issues, and see what their return policy is if they don't fit. other than the fitment issues, their tanks look great. I knew up front I could not return as I ordered a non-typical color. I think red, black and white are all normal stock colors.
    Nov 2004
    Waterloo IL
    2,701
    What color did you get? Hopefully your repair will work. I haven't seen much success with repairs similar to this. I'd be curious on the long term durability.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    NEPA
    7,051
    Boy,,this seems so simple to me. Send them all of their non fitting garbage back and get a refund. This is absolutely unacceptable. Unless they come with the sales pitch that they WILL NOT FIT THE MACHINE YOU ARE BUYING IT FOR.
    OK
    5,450
    Quote Originally Posted by atc007 View Post
    Don't forget you have to pay to ship it back, and the restocking fee. Been there done that. Clarke will never see another dime of my money.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
