Thread: OK I have an idea for my 110KLT
    Mountain Home, AR 72653
    500
    OK here I sit on an idea and most of the parts. Can a man build a fully suspended 110KLT with disc brakes and be somehting worth appreaciating? IMO yes it can be done and I think it woudl be awsome.
    And this is what i have and this is what I see.
    I see a full front fork setup with disc brakes. Hmmmmm need a triple tree to fit the 110KLT and one be wide enough. Two be adaptable to the front shocks.
    Now I see a rear shock for a fabricated swing arm and again disc brakes.
    What do you guys think? Any ideas?????
    Thanks, 110KLT
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    Michigan UP
    1,005
    Looks like a good start to an atc70 project
    Southern MN
    1,875
    You have to be able to do the fabrication yourself, or have a really good friend to help you out. The machining, welding, and labor alone would cost a couple thousand. Is it worth it? If you have the right equipment, know how, and materials it is. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Ripley Tn
    1,363
    http://www.3wheelerworld.com/showthr...ht=powroll+klt
    find a set of front tripples for a 90 or 110
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    500
    Quote Originally Posted by motoman1012002 View Post
    is the down tube size the same for honda and kawasaki?
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
