Results 1 to 15 of 16
Thread: 85 R axle o-rings?
    Aug 2011
    Sacramento
    41
    85 R axle o-rings?
    When installing my axle on the 85 I found this in the Shop Manual on page 11-7:
Name:	axle o rings.jpg
    I don't think I remember o-rings there when I disassembled it. Can someone enlighten me here please? Are these necessary? They didn't come in the All Balls kit I don't think.
    Trackburger's Avatar
    Trackburger is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Virginia Beach
    254
    They prevent water / dirt / mud from entering between the bearing carrier and carrier housing. Can you run it without the orings.... sure. just know that if you ride in lots of water and mud it will find its way into the void and make it a pain in the arse to adjust your chain. Running your trike without the rubber where the allen heads are to loosen the carrier housings "grasp" on teh carrier will do the same thing. If you rode on grass all day etc you would never have an issue, but its fine to ride until you get the orings. Just make sure you clean it out well after you get the orings and use plenty of marine grade grease to keep everything lubed and moving free.
    1985 Honda ATC 250ES BIG RED
    1985 Honda ATC 350X
    1985 Honda FL670R Odyssey ROTAX conversion
    1993 Honda Type II 200
    2003 Honda TRX 90
    2006 Honda TRX 90
    Apr 2005
    Virginia Beach
    254
    nevermind... I just looked at the pic you posted and I'm thinking of the wrong O-rings. Not sure aout those either.....
    1985 Honda ATC 350X
    2003 Honda TRX 90
    2006 Honda TRX 90
    Aug 2011
    Sacramento
    41
    It's really weird because in the exploded view it doesn't show the same o-rings like the assembly drawing above shows.
Name:	axle exploded view.jpg
    SOMEONE must know what I'm talking about here... hundreds if not thousands of you have replaced an axle before. I searched and couldn't find any mention of it which I thought was strange.
    May 2011
    eden,ny
    3,481
    looks like a grease seal to me. I just looked at a parts fiche,It didn't show any o-rings. Is it a factory service manual or a clymer or something?
    Blossvale NY
    4,563
    I know my '85 doesn't have them.... strange
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Aug 2011
    Sacramento
    41
    Quote Originally Posted by just ben View Post
    These two drawings are from the '85-'86 Honda Shop Manual. I haven't looked at the online fiches yet. It's not the dust seal; it's something additional to that I guess. The more I think about it, the more I think it's a mis-print because the sprocket hub and the brake hub are supposed to butt directly up against the bearing (correct me if I'm wrong).
    Each outer bearing in the carrier, those MUST have a seal.
    Near the pinch bolts, some say you need them, others feel otherwise. If you don't run those, plan on sliding the carrier and greasing it up once in awhile unless you enjoy ruining/chewing up your carrier because crap gets in there.
    The disc brake has yet another o-ring.And the carrier itself should also be greased so it will adjust the chain easily.
    I use Bel-Ray waterproof grease on all mating surfaces, thicker grease on splines and I'm yet to ruin any part to date
    Aug 2011
    Sacramento
    41
    I installed the seals, but what about the o-rings in this drawing... have you ever seen these?
    I'm using both the pinch bolt seals and the big o-rings on the outside of the carrier.
    What o-ring is this you speak of????
    I piled on the Bel-Ray; heard good stuff about it so I got some too.
    Carthage NY 250r rules
    2,355
    My 85 and 81 both had the o-rings on the axle.Its a thin o-ring that goes on the inside of the axle spocket hub and brake hub.Both my 81 and 85 I was the first one to take them apart from the factory.They are there to keep water from coming threw the srocket and brake hub splines.
    250r rules
    The disc brake hub has a groove in it for an o-ring.
    Jul 2011
    Colorado
    141
    Helidad,
    atc300r and Crasher are correct. The O-rings you seek are very thin and usually break apart with old grease and grim on old axles. Very easy to overlook when removing the sprocket and disc hubs.
    Checkout an online parts listing like Service Honda.
    Aug 2011
    Sacramento
    41
    OK, I believe all of you, and THANK YOU ALL for helping a new triker, BUT, I still can't see where these two o-rings go . I don't see the groove in the brake hub either.
    As a side note, not sure if it's significant or not but I have an '86 axle going into an '85 everything else. I have noticed some differences like the '85 wheel hub doesn't go on the '86 axle without the spacer going on first!
    Back to the o-ring problem; can someone please post a picture of the locations of these o-rings? Like a good, clear picture??? And a picture of the groove mentioned by
    Crasher in the brake hub?
    I looked at the online fiches at Service Honda and found these o-rings (39.6 X 1.3) but these don't look like the location that we're talking about here (again, please correct me if I'm wrong).
Name:	Axle parts fiche.jpg
ID:	148329Click image for larger version.
Name:	Axle parts price list.jpg
    Thanks again you guys!
    I love this website
    Screw it, grease it up nice and don't do any "snorkel type riding" I tear them apart near yearly and grease them all based on usage anyhow.......
    Aug 2011
    Sacramento
    41
    LOL. I'm at that point. After reading dozens of threads on the bearings and swinger issues, I'm tearing it apart regularly anyway. Wouldn't turn down the pics though.
