Thread: Tecate fork seal driver help
    Aug 2010
    Southern Oregon Coast
    932
    Question Tecate fork seal driver help
    I'm in the process of rebuilding the forks on my 86 Tecate. I have read about using a piece of abs or pvc as a seal driver. The problem I'm running into is the Tecate forks are larger. I have a piece of 1 1/2" pvc that has the flared end. The regular end of the pipe wont fit over the upper tubes and the flared end won't fit in the tops of the lower tubes. Maybe I'm missing a step or some thing...
    Any insight is greatly appreciated
    Tucson
    1,652
    Take a piece of pvc thats not flared about 4'' to 6'' long and cut it into four sections, then put them around the fork tube evenly , using two hose clamps one on top an another on bottom tighten them down!! make sure they are also flat on the bottom so you put the seal in perfect..
    Dean
    3 or die's Avatar
    3 or die is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    southeast
    198
    I don't have a book. I'm building mine too. How much fluid goes in a 86.
    The Punisher!
    Aug 2010
    932
    Thanks for the help. I got it all together. super easy btw.
    3ordie, get your manual here, you'll need the 84/85 manual too, as the 86/87 share much of the same info:
    http://www.oscarmayer.net/atc/manuals/
    It calls for about 500 ml after disassembly, but I think whats is more important is the fluid level measurement. (in the manual)
