this winter im going to be splitting the case on my 85 200x to fix the kick start return spring. might as well rebuild the top end and such right? I am getting a new cam from web cams, bumping the comp to 10.25:1 with a weisco, overbore if it needs it or just hone it (well not me... a shop), timing chain, uuum..
i dont want to go crazy. but i do want it to be reliable and have a bit more power. maybe someday ill get some new exhaust for it too. but as for performance all i plan on is a cam, piston, and pipe. it shifts great and the clutch is good. starts like garbage and wont idle (new carb ON the way, the old one was mangled by the previous owners).
all in all im looking for reliability really. what else should i look for while im in there? i want to start knowing what i should buy now or how much i should plan on spending when the time comes. are there ever any problems with lower end bearings? ive read that the cam bearings can be a problem. also my kick start shaft seems to have some side play. is this normal? or am i going to need to get more then just a spring?
any help would be great!
Trikes (sold)
) (now sold again)
