i heard that you can ship a 70 for about 65 dollars if you take off the forks and put them in a seperate box is this true
1985 atc 70 (sold)
1985 200x dg pipe and k&N filter
need rear brake caliper for 200x
UPS has a weight and size limit on packages. They also won't ship a machine with gas in the tank. Be sure to drain it completely.
To ship a 70 I would do it this way: Remove the foot pegs, rear tires and axle, the rear fenders, and the front tire and fender. I then unbolt the handlebars from the forks so they can be turned. Then I make or find a box that the remaining chassis will just fit in. Do not seal the box yet.
Then you need to find a box that the remainer will fit in. It will need to hold 3 tires, fenders, foot pegs, & rear axle. You will need to package this box cunstructively to keep the size down as much as possible. You also need to use extra care to keep from causing damage in transit. But it can be done.
For packing material I use a lot of shredded newspaper. It gives a good cushion. I have the kids shread newspaper with a paper shreader.
I hope this helps.
Howdy
I have recieved one of these cunstructively packaged boxes. All I have to say is I bet Howdy could ship a house in 2 boxes and still have room to throw in a trike somewhere.Originally Posted by Howdy
I had the RIGHT to remain silent, I didn't have the ability!
i went to ups.com and estimated my shipping costs and it came out to be about 135 dollars is that about right or is it too mutch or too less
1985 atc 70 (sold)
Howdy sent me a trizinger in 2 boxes. I can't rember exact shipping cost but it was $60-70 to ship it. I think it was shipped a little over 1000 miles.
Trust me it was packaged very tightly and constructivily :shock:
Josh
$135 seems a little high,but i guess it depends on where and from its going to.Originally Posted by whiteboarder
R.I.P Raven
2006 Yamaha Banshee Special Edition
1996 Honda CBR 600 F3
The actual shipping cost was $70 and some change. As Josh said: The package was tightly packaged. It was done with care and a lot of thought. A mouse would have been cramped. heheOriginally Posted by smokinwrench
Depending on the distance $135 does sound high. But if you look at it another way: forwardair would cost a lot more.
Howdy
It also depends on how its broken down. Make sure none of your packages exceed 70 lbs. Each additional pound over 70 is $5 per pound, and its cheaper to go to another pcackage at that point.
Also packages going and coming from Washington and Oregon are most expensive in the cont. US.
