Results 1 to 2 of 2
Thread: 200M vs. 200S brake drum
    Jun 2012
    New England
    7
    So, after my dad & I apart the rear axle assembly on my 200S to find out why the axle was sliding, I found out that it had no brake drum. I decided that it was a good idea to use the one from my 200M, but when my dad tried putting it on, he thought it wasn't going to fit because it felt like a tight fit and this is just with the brake shoes lacking in friction material. My question is, are the brake drums from the Honda ATC 200M & ATC 200S interchangeable? Based on what I saw in the brochure, it looks to be so, but if the thing really is tight like my dad said, is there any way to adjust the shoes?
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    yes they are interchangeable i believe
    you should be able to loosen the nut on the end of the pressed steel lever on the end of the brake cam
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
