Results 1 to 15 of 19
Thread: yamaha 200e moves in reverse freely when gear why
    Jun 2012
    Belden, NE, USA
    142
    someone please help
    Jun 2012
    Belden, NE, USA
    142
    is any one there
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    83-84 ytm-200E: shaft drive, no reverse ,pull starter and electric starter
    85 ytm-200E : shaft drive , pull starter electric starter and reverse.
    I think that's it. Mine doesn't have reverse I wish it did.
    Jun 2012
    pa
    292
    How do you know it has reverse Just asking I have never seen one with.
    Jun 2012
    Belden, NE, USA
    142
    that not problem when in gear not running it moves backwards had to pull in behind pick to get to start it will not go on it own do not know what is wrong with it
    Jun 2012
    Belden, NE, USA
    142
    Jun 2012
    pa
    292
    I don't drive mine much I'm the 2 owner with title almost new that why, but my 225dx's are shaft drive and all 4 of them when i put them in gear the move freely. Its hard to bump start them. Why don't you pull start it?
    Jun 2012
    Belden, NE, USA
    142
    tryed but will not work it been 3 or 4 year since it was started that
    Jun 2012
    pa
    292
    Clean the carb and go threw the jets with a wire clean them really good, maybe new spark plug. It should fire up. Mine a fussy I clean the carbs all the time jets always clog up. Good luck Let me know how it works or any other questions. Maybe some one else can even help. Here is the manual http://www.oscarmayer.net/atc/manuals/
    Jun 2012
    Belden, NE, USA
    142
    it work to get started but would not stay running in neutral then tires would not brake free and take think shaft might locked up shaft driven atv do not know much about them
    Jun 2012
    Belden, NE, USA
    142
    thank for the help
    Jun 2012
    pa
    292
    Still think the carb needs cleaning jet is blocked. In neutral it wont roll? Tires pumped up?
    Jun 2012
    pa
    292
    Np good luck. I never had a shaft lock up tho.
    Jun 2012
    Belden, NE, USA
    142
    iv clen carb did all that that problem carb need set best why set carb is to have it running tire full air im going to guess your kid i need bigger help then what u can give thank any ways
    Jun 2012
    pa
    292
    Lol I have and had more trike alone that you can even think over the last 26 years. I cant understand what you mean anyway. good luck.
