Results 1 to 15 of 48
Thread: How do u know shaft is locked up
    Jun 2012
    Belden, NE, USA
    142
    when 3 wheeler is not runnig i put it in gear will not move foward but moves back freely is not right i could not get it start it an old tri was not running for 3 or 4 year a least i pulled it behind truck to bump start it started but tires did not move freely and when put back in Neutral it dies
    Mexico
    9,020
    Recommend you open up the cases to see what sort of shrapnel is in there and brush up on the grammar before posting what you find if you are still looking for help.
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    It might be the bottom-end, He told me he pulled it with a truck 20mph and put it in 1st gear.
    Mexico
    9,020
    Quote Originally Posted by tripowersport View Post
    OMG, I hope it was on loose gravel and not pavement
    Jun 2012
    pa
    292
    I think He told me, but I couldn't understand him. he cleaned the carb, but the only ways to start it is to compression start it and when he stops it dies, crank seals?
    Jun 2012
    Belden, NE, USA
    142
    i was trying to get help not grammar lessons it was not 20 i just said cause u were being rude and it was on gravel this is not my fist try at this my dad has been mechanic his whole life so know my way around a shop and tools i have never had a shaft driven atv. ive all was had chain driven this 3 wheeler is in ruff shape it fixer upper so if u have had any thing this happen let me thanks by it not grammar it im bad with key board
    Jun 2012
    Belden, NE, USA
    142
    key boarding skill if that make more sense
    Jun 2012
    Belden, NE, USA
    142
    ok when 3 wheeler is in gear it does not move forward but moves backwards freely is this right. it is shaft driven and yes cleaned the carb do u think the shaft is locked up or is this normal. when i pulled it be hide the truck i got it to start but the tires were locking up. is there any reason y it would do this. im trying to get answer sorry about the grammar im really getting up set with this project. sorry i was not watching what i was typing.but when u answer with half baked answer and u do not understand what one is asking that does not help so u do not understand what some one is asking maybe u should keep your answers to your self thank for the help
    Mexico
    9,020
    Having read your posts (a number of times) I am convinced that the best thing for you, your "tri" and the well-being of the three wheeler world in general is that you part it out and get a quad, preferably one that is running. Best regards.
    Jun 2012
    Belden, NE, USA
    142
    that not what advise i was looking for already have have honda 200 x that is like brand new the three wheeler can be fixed it not that bad i will keep looking for advise thank
    Jun 2012
    Belden, NE, USA
    142
    have you ever fixed one that had not been running or has not been running for couple or years
    glendive, montana
    1,822
    first off a shaft driven yamaha has a ton of torque in first gear and it will lock the tires up when trying to bump start it you should always try to bump start in third or fourth gear. Also yes it will not move forward in first, but freely in reverse, as the clutch is centrifugal and only engages when spinning the right way. Now on to why it won't run, I will give you a check list of things to do, and after that then check back with us.
    change oil and oil filter, and check for metal shavings
    clean carb thoroughly
    clean fuel tank and petcock
    do a compression, and leak down test
    check spark, and look for bad connections
    after all that and everything is good, but it still won't stay running, I want you to take the carb back off and clean it again, this time be even more thorough, if you need I have a link to a repair manual that can show you all the parts to the carb including some jets and o-rings that are really tucked away and can give you a major migraine.
    Jun 2012
    Belden, NE, USA
    142
    you sound more like a rider then mechanic do u know and mechanic i can talk to
    Jun 2012
    Belden, NE, USA
    142
    thank u some who know what they are talking about ive done alot that on your check list the spark is blue instead of white im working on that
    Jun 2012
    Belden, NE, USA
    142
    new spark plug connection all good beside the shut off switch has been removed by some else wire were cut underneath check with meter to make was same wire that were in the switch all other connection were good i will be taking carb back apart it normal thing for me to do. i like to keep them clean i might be replacing the floats the they looked like they had burn marks on the float
