huh, I tried it 3 times it worked for me idk sorry.
that ok thank the page come up but when click on the next step pull up blank page
it takes a long time to load, i'm down loading it now and ill try to copy and paste it for you.
I have it now but I cant paste it in here, pm private message me your email and i will email it to you.
the oscarmayer page loads for me and if you right click on the link to the manual, you can download it which will be easier to use than trying to load the manual on the net every time, also here is a link to the carb disassembled for you http://www.hondapartshouse.net/pages...00EK_-_1983%29
or http://www.hondapartshouse.net/pages...200K_-_1983%29
depending on which carb you have
I think he has a 84ytm200e, I sent him the ytm200 one. Thanks for helping tho.
Where did you find that on the honda site?
lol, never mind wrong page.
that ok i have honda 200x as well my hat off to both of u hAVE been alot help got all back together but still can not get it to start with rope cleaned carb realy good wire carb cleaner i thinK spark plug problems might be the case have new spark plug but spark is blue it shouLd be white right
Check your spark timing. Also could be you sheared a flywheel key when bump starting or jumped out of time even. Use a rubber ended air hose to blow out the carb better when cleaning. Is the plug wet after your failed attempts to start it?
No blue is good.
what plug are speaking of
i got it spark plug ill check that next time i try thx and air hose one of the jet was plug i got it unplug with carb cleaner can see through it now could not before
if spark plug is not wet then what
