Spark issues on my Kawasaki tecate
Hi.
I have replaced my stator,coil, and flywheel and still only a weak spark .
I was kick starting it with my hand (with spark plug out) I leaned on the frame and got shocked and was not even touching the spark plug wire what is going on here ?????
Maybe bad wire or ground. Is the ground wire on by the coil? I might be wrong just guessing.
I just got done messing with mine, I thought the carb was messed up it was braking up. The coil mount broke off lol.
I don't know if you have or need a manual but here it is. http://www.oscarmayer.net/atc/manuals/
Oh check the kill switch maybe that's it,But I did have to replace my cdi,stator and flywheel on mine. good luck.
My cdi box is all I have not replaced brand new but my stater , fly wheel and coil are all new . I have done so much work to this bike it's been powder coated .the rear ends been extended had the motor rebuilt and i can't even ride it .
I unhooked the kill switch wire unhooked the head light power just to maximize spark and everything is mounted in factory spects as far as I know
Oh, No kill switch or light......Make sure all the wires are ok and the ground wire is on the coil. I don't remember if there is a ground wire on the stater but there might be. Sorry that all I can think of now, If I think of some thing ill let you know. Maybe someone else will help also. Do you have any pics? It sounds like your doing a hell of a job.
Don't sweat it you are on the right track and you will get it, It took me 2 years to do my show one.
Is there a Tail light on it If so how are the wires?
Thanks for all the ideas you guys .I have some pics and would love to share them with everyone as soon as I figure this out .I have had the bike done for about 8 years it was done the first year I owned but ran into the spark issue and it's never ran since so i just put it away would be nice to ride it though
I took the stater all apart last night and checked all the wires for cracks or wear marks .I found nothing all still in brand new condition I have heard that a hair Line crack will ground out on the frame .
Did you do a ohm test? You didn't have to take it out for that,but it doesn't hurt.
Make sure the ground wire is on where the coil is mounted with good ground to the frame sand it a lil. check the whole wiring harness from back to front,down to up lol. good luck,Yes please put pic's on.
I dunno how to post pics yet. I'm on my iphone
I have a picture of my green machine on my Facebook my email is . Ajjr.snider@yahoo.com your more than welcome to ccheck it out
//ArrowChat Integreation Code
