Tri z carb upgrade
Hi just a quick one, am I right in saying the standard carb Is a 34mm and a 35mm airstriker will squeeze in?
Thanks
I cant find it in my manual, here is the manual. http://www.oscarmayer.net/atc/manuals/ maybe some one else will know, good luck.
yes it will I run PWK carbs,,, and a 39mm will fit but you got to heat up the boot.. or go into the 3ww store and buy a sprock intake.. they have bigger rubber.. 38-39 slip rite in.. good luck.. these carbs are awesome!
Yea Brian??????? That's great thort IDE have to adapt some intake on it if I went bigger. I've seen a few 38's on eBay. Think that's going to be a plan
Pwk carbs?? What does that meen ?
Thanks
What does the pwk stand for on the airstikers?
//ArrowChat Integreation Code
