Results 1 to 6 of 6
Thread: 350x leaking oil from cam cap
    Jun 2012
    Perkasie PA
    15
    First time I started my new project 350x it spit oil out from the cam cap. Does this indicate head damage or do I just need to reseal the rocker cover? Does the rubber cam cap come in a top end gasket kit?
    gus's Avatar
    gus is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2011
    tucson arizona
    453
    If its leaking g out of the cam cover check your rubber seal? Im not sure if they come in a gasket kit have you looked on eBay?
    Jun 2009
    Leander TX
    2,217
    The rubber cam cap is like $10 from Honda.
    No gasket under the cam cover - I use Permatex anaerobic sealant.
    Also, check the sealing washers on the external oil line.
    Apr 2010
    KS
    65
    Quote Originally Posted by Tom'85350&70 View Post
    I left you a link to your post over on honda350x.com
    Jun 2012
    Perkasie PA
    15
    I'll check it out thanks
    Jan 2011
    Choctaw, OK
    2,755
    If its leaking from around the cam cap then the rocker cover needs to be resealed.
