Results 1 to 12 of 12
Thread: Do Tecates eat sparkplugs or just mine?
    unclecracker's Avatar
    unclecracker is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    goshen, indiana
    294
    So I have two 84 Tecates. Both want to eat spark plugs after a few minutes of riding. One the plug looks fouled (high oil) the other looks light tan (low oil), I've never had this problem with 250Rs I've had before.
    I've tried the following:
    Adjusting carb
    New fuel with proper mix using Golden Spectro oil
    Pegging the accelerator open majority of the time
    I had the stator and CDI checked by mechanic
    I'm at a loss...Click image for larger version.
    Jan 2011
    Greene,Ia
    688
    i have never fouled a plug in my 85 t3....but its weird both of yours are fouling....
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    NEPA
    7,049
    Anything that is properly tuned will not foul plugs. I would look at your stator and flywheel again,if your ignitions good. Pressure test your engine,then go to carb,,where you will probably find the problem.
    My Tecate had the same plug in it for probably better than three years. You've got something wrong. You're not using Champion plugs or something silly like that are ya?
    Jul 2008
    goshen, indiana
    294
    Nope, NGK-R. BR8-ES.
    What should I look for in the carb?
    blackstone/ma
    1,491
    I have two tecates and neither eats plugs. do self a favor and buy a new carb for 85$
    Nov 2004
    Waterloo IL
    2,701
    I don't think I've changed the spark plug in my Tecate since I've owned it. You definitely have a problem there. When I've had a bike that might not have been tuned 100% correct and went through a bunch of NGK-R plugs I went with a non-resistor and that took care of it. Try a B8ES.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    blackstone/ma
    1,491
    I run b8es as well
    They seem to enjoy a diet of flywheels and stators more than plugs.
    They also have the ability to shed weight incredibly fast by vibrating themselves apart...
    NEPA
    7,049
    Yes,,I don't even run resistors in fuel injected sleds,,which is a no no.. They suck. Run a B8 or 9 es..
    Jul 2008
    goshen, indiana
    294
    Thanks for the tip - I will be purchasing some B8ES and see if that helps!
    May 2011
    eden,ny
    3,481
    of the 6 tecates I have had, I only fouled one plug and that was due to crank seals.
