It cleans up with water until it gets some age on it, then its a nasty gooey mess that takes a brush, power washer, cussing, sweating, possibly kicking it across the yard... Ok so you probably get the point that i have been through this.
Another problem? Up here in the great Midwest when its -20 outside and you have to deal with a tire that was slimed in the summer. That stuff doesn't always totally freeze, it depends on how much moisture is in the air put into the tire and any moisture that was in the tire to begin with, but it will either freeze and throw off the tires balance or it will turn into this thick molasses like green goop that you literally have to scrape off and then scrub off. Its not fun.. I to have dealt with it. The farmers around here will put it in anything, i mean anything. If its a tire and has a leak it gets slimed cause its cheaper than taking it to the local tire shop. But ask the local tire shops what they think of when they finally get that slimed tire after its been used for a year or two.. Ugh..
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
