200x Rotr Bolt
Does anybody have a picture or can take a picture of the bolt that hold's the rotor on the crank for the 83-85 200x,part #90112-KA2-000 local honda shop has had the bolt on B/O for last 2 weeks and dosent seem to think that they will be able to get one.Service honda says it's still available though. But if anybody is good at cross referencing then I think this part number is for the same bolt 90006-MGE-010 just a newer number I beleive. Is there anything special about the bolt I should know about if I decide to source it elsewhere??? Thanks
Chris
Nothing special about the bolt to my knowledge. However, if I were you I would stick with OEM. I would try to order from service honda or bikebandit. The bolt is still available on both websites.
Feedback for yaegerb:
Click Here
Got looking around and it seems that the Bolt im looking for is a UBS Bolt? Any ones that I managed to find a picture of have two sets of threads. Has anybody had there 200x rotor off lately and noticed this about that bolt, im thinking it bolts into the rotor aswell as the crank with oposite threads somebody follow me? Also opened up the kicker and no thrust washers, it's an 84 and 1 of the two are discontinued, 83 has a different washer by.2mm and is not discontinued is there a reason for this can I use this washer instead? Thanks
Chris
Are you talking about the bolt that holds the flywheel onto the end of the crank? If so I might have a good used one. I know I have at least 2 flywheels so I figure I have to have the bolts somewhere too
When you say rotor I think of a brake rotor or the oil rotor filter thing inside the engine.
Rob
yes that would be the bolt, has a washer behind it. I have the washer but no bolt.
//ArrowChat Integreation Code
