Results 1 to 7 of 7
Thread: 1982 Honda 200 Problems. HELP!!!!!
    Jun 2012
    Bruce, MS
    72
    Ok I have a 1982 Honda 200. When I bought it, it would bob up and down on pavement and shake you to pieces. I assumed it was the front wheel bearings so I replaced them and it still does it. It is getting on my nerves. It works fine on dirt but on any pretty solid surface (pavement, gravel) I can hardly keep it straight. I don't ride much on pavement (only a couple miles to some trails) but I just can't hold it steady while trying to get to them. It does have front fork extenders but I don't know if they could be causing the problem. I really need to know what all I should look at to get this problem fixed so I can enjoy my trike. Thanks.
    1982 Honda ATC200
    1980 Honda ATC70
    1983 Honda ATC110
    Springfield Mo
    3,309
    Have you checked your fork alignment to see if they are straight? Have you checked to make sure that your axle is not bent? Have you checked to make sure you have the same rear wheel circumference and air pressure?
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Maine
    463
    warped rim or somethings bent...what kind of tires you got on her lets see a couple pics of the back of the trike
    Dec 2009
    Oklahoma
    780
    Put it on a milk crate and run it through the gears.
    Dec 2009
    Oklahoma
    780
    opps, you will see right away if it's a front end problem or a axle/wheel problem
    MN
    3,260
    Most common causes in my experience, the steering bearings, different tire pressures on the rear, bent axle, bad wheel bearings.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jun 2012
    Bruce, MS
    72
    i just set it up on a brick earlier and found the front tire is pretty bad. it has a weak spot and a huge knot on the side of it that i completely overlooked. im getting a new tire soon to try it out.
    1982 Honda ATC200
    1980 Honda ATC70
    1983 Honda ATC110
